[OpenLayers-Users] GetFeatureInfo map.events.register for *many* WMS layers
Andreas Hocevar ahocevar at opengeo.org
Mon Sep 14 15:12:07 EDT 2009
Just remove the line
OpenLayers.Event.stop(e);
for all but the 1st layer.
Regards,
Andreas.
cgp wrote:
> I have about 10 or more WMS layers that I'm adding to the map. I'm using
> GetFeatureInfo to get values for each layer. So I have 10 of these:
> map.events.register('click', map, function (e) {
> 	if (map.layers[layer_index].visibility==true) {
> 		var params = {	REQUEST: "GetFeatureInfo",
> 					EXCEPTIONS: "application/vnd.ogc.se_xml",
> 					BBOX: map.getExtent().toBBOX(),
> 					X: e.xy.x,
> 					Y: e.xy.y,
> 					INFO_FORMAT: 'text/html',
> 					QUERY_LAYERS: map.layers[layer_index].params.LAYERS,
> 					FEATURE_COUNT: 50,
> 					Styles: '',
> 					Layers: layer_name,
> 					srs: 'EPSG:900913',
> 					WIDTH: map.size.w,
> 					HEIGHT: map.size.h,
> 					format: 'image/png'	};
> 		event = e;
> 		OpenLayers.loadURL("http://app-serv-01-uat/geoserver/wms", params, this,
> setHTML, setHTML);
> And since I have 10 of those for each of the 10 different layers, my code is
> getting too long, messy and unmanageable. I tried to refactor it by creating
> a for loop:
> var layers_names = new
> Array('sde:forests','sde:lakes','sde:trails,'sde:boundary','sde:buffallo','sde:fish','sde:birds','sde:picnic_sites','sde:rivers','sde:camping');
> var layer_indices = new Array(5,6,7,8,9,10,11,12,13,14);
> var layer_name;
> var layer_index;
> for (var i=0; i<layers_names.length; i++) {
> 	layer_name = layers_names[i];
> 	layer_index = layer_indices[i];
> 	alert(layer_name+" "+layer_index);
> 						X: e.xy.x,
> 						Y: e.xy.y,
> 						FEATURE_COUNT: 50,
> 						Styles: '',
> 						Layers: layer_name,
> 						srs: 'EPSG:900913',
> 						WIDTH: map.size.w,
> 						HEIGHT: map.size.h,
> 			event = e;
> setHTML, setHTML);
> My problem with this is that the click event sticks to the last array value
> only. In this example, the GetFeatureInfo will only be fired on layer 12,
> 'sde:camping'. For the rest of the previous layers, it won't fire at all. I
> might be missing something, so can someone help me out? Thank you very much.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
