[OpenLayers-Users] GetFeatureInfo map.events.register for *many* WMS layers
Ian Turton ijturton at gmail.com
Mon Sep 14 15:22:37 EDT 2009
You should probably use the same variable for the layers and
query_layers parameters - there is some debate over whether they must
match or not (GeoServer atleast requires all the query layers to be
listed in the layers param).
I'm also not quite clear as to why you can't roll all the layers in to
one request?
Ian
