[OpenLayers-Users] Firefox 3.5.3 not displaying controls
Mike Quentel mikequentel at yahoo.com
Wed Sep 16 11:44:37 EDT 2009
Andreas, thank you for the ideas.
I solved the problem (viewing OpenLayers map viewer in FF 3.5.3 on WinXP) without knowing why the problem happened...
THIS SOLVED THE PROBLEM: I found that if I uninstall Firefox--and this is important: remove all local settings/information associated with Firefox during the uninstall--then re-install Firefox, OpenLayers will then properly function.
THIS DID NOT SOLVE THE PROBLEM: On the other hand, if I un-install FireFox but retain the local settings data, then re-install Firefox, the problem persists.  Also, attempting to uninstall all Add-Ons did not solve the problem.  Likewise, trying different language versions of FF did not solve the problem.
I am not clear if the problem was caused by a registry issue or simply some setting/file/add-on data in %TEMP%.
 Mike Quentel
----- Original Message ----
To: Mike Quentel <mikequentel at yahoo.com>
Cc: OpenLayers Users <users at openlayers.org>
Sent: Monday, 14 September, 2009 11:01:57
Subject: Re: [OpenLayers-Users] Firefox 3.5.3 not displaying controls
Mike Quentel wrote:
> On my laptop running Firefox 3.5.3 on Windows Vista Home edition, there is no problem viewing OpenLayers map viewer (for example, the one on the home page for OpenLayers.org).
> But on my Windows XP workstation, running Firefox 3.5.3, the map controls do not appear.  Firebug says "Error in parsing value for 'filter'.  Declaration dropped".
Can it be that you changed the User Agent string on your XP workstation
to something that makes OpenLayers think it is using Internet Explorer?
Or that your browser is configured to override some CSS properties?
Regards,
Andreas.
> Anyone else experience this error?  Could it be Firefox plug-in conflicts?  Any work-around?
> Thanks,
>  Mike Quentel
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
