[OpenLayers-Users] GML Overlay
Dash jimlug at co.clackamas.or.us
Wed Sep 16 17:15:14 EDT 2009
Well, I figured out the answer.  The Data Interop. Tool by ESRI outputs the
coordinates in a lat / long format.  Well, OpenLayers and the GML file
require the coordinates to be in a long / lat format.  What a pain in the
butt!  Now, does anyone know how to fix that?
Dash wrote:
> Christopher Schmidt-2 wrote:
>> On Tue, Sep 15, 2009 at 11:42:47AM -0700, Lugosi, Jim wrote:
>>> I am trying to figure out how to use the GML overlay with OpenLayers.  I
>>> have searched high and low for examples and nothing seems to help.  I am
>>> currently trying to convert a shapefile to a GML file using ESRI's Data
>>> Interop. Tool.  I've used both the quick export and the Spatial ETL
>>> Tool.  Everything seems to work, but when I try to display the
>>> information on my map nothing shows up.  There are no JavaScript errors
>>> and the layer shows up in my LayerSwitcher control so I really can't
>>> tell what the problem is.  Also, I've dumbed down the process by
>>> creating a shapefile of a box so that I don't have a large number of
>>> coordinates.  Could someone please help with my dilemma?
>> http://docs.openlayers.org/help/minimize.html
>>> Thanks...
>>> James Lugosi
>>> Clackamas County - GISP
>>> www.clackamas.us/gis
>>> 503-723-4829
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Christopher Schmidt
>> MetaCarta
>> Users mailing list
> Dash wrote:
>> I understand that you are probably trying to help me without words but a
>> little more than just a link would help.  Believe me, I've removed lines
>> of code and simplified everything I could.  I guess the next step would
>> be to post the code.  Here is the init function I use when launching the
>> page:
>> var map, layer, popup;
>> var markers, feature, marker;
>> function init() {
>> 	// Default map projection is ESPG:4326 -> WGS 84
>> 	// WGS 84 Bounds: -180.0000, -90.0000, 180.0000, 90.0000
>> 	map = new OpenLayers.Map('map');
>> 	// Initiate Map Controls
>> 	map.addControl(new OpenLayers.Control.LayerSwitcher());
>> 	map.addControl(new OpenLayers.Control.MousePosition());
>> 	// Create Google Layers
>> 	var gmap = new OpenLayers.Layer.Google("Google Streets",{numZoomLevels:
>> 20});
>> 	var gphy = new OpenLayers.Layer.Google("Google Physical", {type:
>> G_PHYSICAL_MAP});
>>     var gsat = new OpenLayers.Layer.Google("Google Satellite",{type:
>> G_SATELLITE_MAP, numZoomLevels: 20});
>>     var ghyb = new OpenLayers.Layer.Google("Google Hybrid",{type:
>> G_HYBRID_MAP, numZoomLevels: 20});
>> 	// GML
>> 	var oc = new OpenLayers.Layer.GML("Box", "./textbox.xml");
>> 	// Add layers as an array
>> 	map.addLayers([gmap, gphy, gsat, ghyb, oc]);
>> 	// Zoom to the passed in bounds
>> 	//boundsExtent = new OpenLayers.Bounds(-180.0000, -90.0000, 180.0000,
>> 90.0000);
>> 	boundsExtent = new OpenLayers.Bounds(-123.562589253, 44.729986898,
>> -121.568458954, 45.918452947);
>> 	map.zoomToExtent(boundsExtent);
>> Here is the GML file that was created:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <gml:FeatureCollection xmlns:gml="http://www.opengis.net/gml"
>> xmlns:xlink="http://www.w3.org/1999/xlink"
>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:fme="http://www.safe.com/gml/fme"
>> xsi:schemaLocation="http://www.safe.com/gml/fme textbox.xsd">
>> <gml:boundedBy>
>> <gml:Envelope srsName="EPSG:4326" srsDimension="2">
>> <gml:lowerCorner>45.3117814762066 -122.640406532134</gml:lowerCorner>
>> <gml:upperCorner>45.3820822372628 -122.536820512781</gml:upperCorner>
>> </gml:Envelope>
>> </gml:boundedBy>
>> <gml:featureMember>
>> <fme:testbox gml:id="iddfa35c96-59ff-4423-b062-668e3993b702">
>> <fme:FID>0</fme:FID>
>> <fme:Id>0</fme:Id>
>> <gml:surfaceProperty>
>> <gml:Surface srsName="EPSG:4326" srsDimension="2">
>> <gml:patches>
>> <gml:PolygonPatch>
>> <gml:exterior>
>> <gml:LinearRing>
>> <gml:posList>45.3117814762066 -122.640406532134 45.3820822372628
>> -122.640406532134 45.3819865899688 -122.536820512781 45.3117814762066
>> -122.538255222191 45.3117814762066 -122.640406532134</gml:posList>
>> </gml:LinearRing>
>> </gml:exterior>
>> </gml:PolygonPatch>
>> </gml:patches>
>> </gml:Surface>
>> </gml:surfaceProperty>
>> </fme:testbox>
>> </gml:featureMember>
>> </gml:FeatureCollection>
>> Is there something I am missing?  Any help would be greatly appreciated.
View this message in context: http://n2.nabble.com/GML-Overlay-tp3650992p3659138.html
