[OpenLayers-Users] adding feature to vectorlayer from wkt
karsten vennemann karsten at terragis.net
Fri Sep 18 04:15:26 EDT 2009
ok added this in:
var options1 = {units: 'm', projection: "EPSG:102003", maxExtent: new
OpenLayers.Bounds(-2500000,-1500000,2500000,1500000)};
vectorlayer = new OpenLayers.Layer.Vector("Vector Layer",{layers:
'basic'},options1);
var thestreetgeom = new OpenLayers.Geometry.fromWKT({type:"LineString"},
{coordinates:[[-1930473.64430529, 1513488.44352758], [-1646969.91778704,
1155135.05969326]]},{ style: "default" });
vectorlayer.addFeatures(thestreetgeom);
also added
bounds1 = thestreetgeom.geometry.getBounds();
map.zoomToExtent(bounds1);
Still nothing shows. I was not sure which bounds to take since the wkt will
be dynamically selected form the roads layer out of postgis. So I added the
bounds ofr the whole map - no idea if this is valid but no errors there.
To check the bounds again I added the two lines above to get the actuakl
bounds and to zoom to the feature location.
Using Firebug I found that the inital syntax of the linestirng had one point
that was not recognized - no idea why but it said 'NaN' . The result was
that
thestreetgeom was undefined.
Thus I changed it to the above notation for thestreetgeom and got an object
now. However I get an error now:
thestreetgeom.geometry is undefined
So my feature  object has no geometry defined - no idea why...
Karsten
  _____
From: Michael Shishcu [mailto:micklesh at gmail.com]
Sent: Friday, September 18, 2009 00:17
To: karsten vennemann
Cc: users at openlayers.org
Subject: Re: [OpenLayers-Users] adding feature to vectorlayer from wkt
well, try to add the max extend of the layer and map units (the next is for
meters)
OpenLayers.Bounds(xmin, ymin, xmax, ymax)};
2009/9/18 karsten vennemann <karsten at terragis.net>
hmm I tried now
var options1 = {projection: "EPSG:102003"};
'basic'},options1);
map.addLayer(vectorlayer);
OpenLayers.Geometry.fromWKT("LINESTRING((-1930473.64430529 1513488.44352758,
-1646969.91778704 1155135.05969326))", { style: "default" });
but still nothing shows and no error...
Karsten
  _____
Sent: Thursday, September 17, 2009 23:55
Hi, Karsten
maybe your layer does not have the correct projection?
try
        var options = {..., projection: "EPSG:102003", ... };
'basic'},options );
regards, michael
I am trying to add line features to a vector feature layer in my map
(projection is EPSG:102003, as are the coordinates of the wkt below)
vectorlayer = new OpenLayers.Layer.Vector("Vector Layer");
I do not get any error but nothing shows on my map. Could this still be a
projection problem or am I missing something else ?
Karsten
Terra GIS LTD
Seattle, USA
 <http://www.terragis.net/> www.terragis.net
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090918/4d670030/attachment.html
