[OpenLayers-Users] HELP!!! How implement Filter in WMS Layer
Arnd Wippermann arnd.wippermann at web.de
Fri Sep 18 09:02:13 EDT 2009
Hi salas,
Move the METADATA block into the WEB block and (perhaps not needed, but
reasonable) add the projection to the map and the layers.
Then you should get a result (when your map extent matches the projection
extent).
Arnd
