[OpenLayers-Users] Bounds / Projection
eoinyp eoinyp at yahoo.com
Mon Sep 21 11:21:18 EDT 2009
Thank you Alexandre,
I now realise that the (-180,-90,180,90) system wont work because Im using
EPSG:900913, spherical mercator, which is where The projection
maxExtent: new OpenLayers.Bounds(-20037508, -20037508,20037508, 20037508.34)
comes in.
Thank you.
But Im still stuck as to how to set the map to focus on Ireland. I dont
understand how to define the bounds of a suitable box. Can you give me any
pointers there?
Thanks,
Eoinyp.
Alexandre Dube wrote:
> Hi,
> This should helps :
> http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
> Regards,
> Alexandre
> eoinyp wrote:
>> Hi all,
>> Could someone please explain how to define the bounds of a map?
>> I want to centre my map on Ireland when it initialises, but I am having
>> trouble with the bounds arguments.
>> As I understand it, the maxExtent of the globe is (-180,-90,180,90)
>> A box around Ireland using the same coordinate system is (-13.5, 51.5,
>> -4.5,
>> 55.5)
>> So shouldnt I be defining my map as:
>> maxExtent: new OpenLayers.Bounds(-13.5,51.5,-4.5,55.5 )
>> This doesnt work, unsurprisingly.
>> I found somewhere else the bounds of the world defined as:
>> 20037508.34)
>> which works great, but it shows the entire globe, as I said, I want to
>> focus
>> on Ireland.
>> What coordinate system is this? and how do I translate the area I want to
>> map to this coordinate system?
>> The variable maxResolution also seems to vary from map to map, I am not
>> sure
>> what this should be set to.
>> The documentation doesnt give any idea of the range of appropriate
>> values.
>> Thanks,
>> Eoinyp.
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Bounds-tp3685720p3686056.html
