[OpenLayers-Users] Bounds / Projection
Bill Thoen bthoen at gisnet.com
Mon Sep 21 11:57:57 EDT 2009
eoinyp wrote:
> But Im still stuck as to how to set the map to focus on Ireland. I dont
> understand how to define the bounds of a suitable box. Can you give me any
> pointers there
If your table is in the Google projection already, then you can use
ogrinfo to dump out the extents in the right format. Otherwise just
declare the map to have extents well beyond the limits of the Google
projection, add a MousePosition control and then zoom in on the Emerald
Isle and note its bounds. A third thing you can do is follow Bret
Taylor;s (of Google) suggestion below to go look up the info on the
Mercator projection to get the world bounds of that, then you can
calculate the Google coordinates using ratios between those limits and
your lat/lon coordinates:
> From: Bret Taylor <btay... at google.com>
> Date: Fri, 1 Jul 2005 15:49:38 -0700
> Subject: Re: What type of map projection does Google use for Google Maps
> We use the Mercator projection for our maps. Wolfram MathWorld has a good
> page on the projection (and a bunch of other map projections):
> http://mathworld.wolfram.com/MercatorProjection.html
- Bill Thoen
