[OpenLayers-Users] Performance Tuning in Internet Explorer
jim.meyer at concept-solutions.com jim.meyer at concept-solutions.com
Tue Sep 22 14:12:52 EDT 2009
Hi Christopher,
	We are using GeoServer (not MapServer).  Is there a way to take all
of the client-side options and pass them in a request to GeoServer so that
GeoServer will interpret and style the variable shape data correctly?
Thanks,
Jim
Jim Meyer
Java Programmer
ConceptSolutions, LLC
    We Make Business Intelligent
703.889.8434 [desk]
703.391.9041[fax]
www.Concept-Solutions.com
-----Original Message-----
From: Christopher Schmidt [mailto:crschmidt at metacarta.com]
Sent: Tuesday, September 22, 2009 2:06 PM
To: jim.meyer at concept-solutions.com
Subject: Re: [OpenLayers-Users] Performance Tuning in Internet Explorer
On Tue, Sep 22, 2009 at 01:41:34PM -0400, jim.meyer at concept-solutions.com
wrote:
> Hi Till,
>    We are using a lot of checkboxes on the client-side to generate a
complex
> query that determines which shapes to display.  This information is sent
to
> the server where a complex query runs and returns JSON to the client with
> the shape data.  These shapes are rendered in a different color based upon
> their time to activation.  I don't believe they are static enough to be
able
> to use WMS.
There isn't naything that you can do in OpenLayers that you can't do with
some other server side rendering code -- either using MapServer or some
other
tool. You really aren't going to be able to render that many things at once
in a clientside browser.
Other suggestions people have offered, like setting a max for features
returned at 100 or some such, also likely bear investigation.
-- Chris
> Thanks,
> Jim
> Jim Meyer
> Java Programmer
> 703.889.8434 [desk]
> 703.391.9041[fax]
> From: Till Adams [mailto:adams at terrestris.de]
> Sent: Tuesday, September 22, 2009 1:00 PM
> Cc: users at openlayers.org
> Jim,
> if it is just necessary to *SHOW* the shapes you probably might check to
> serve them as WMS (try UMN  or GeoServer) or pure as UMN-CGI service ?
> Doing that, your performance is an issue of the WMS server and not of
> OpenLayers and there are many screws to work on like indexing,
> scale-dependency and so on...and you are more browser independet,
> because the only thing to show is an png or gif image.
> Till
> > Hi Christopher,
> >    We are rendering active airspaces on our map.  We are required to
> render
> > this many shapes on the map.  Any other ideas?
> > Thanks,
> > Jim
> > Jim Meyer
> > Java Programmer
> > 703.889.8434 [desk]
> > 703.391.9041[fax]
> > Sent: Tuesday, September 22, 2009 11:37 AM
> > On Tue, Sep 22, 2009 at 10:34:42AM -0400,
> > wrote:
> >> Hi,
> >>    We are rendering a vector layer that has 1000+ shapes.  Currently,
it
> > is
> >> very slow in IE.  Any ideas as to where to start to improve
performance?
> > Render fewer shapes.
> > Regards,
> terrestris GmbH & Co. KG
> Irmintrudisstrasse 17
> 53111 Bonn
> Germany
> Till Adams
> Geschäftsführung
> Tel: +49 (0)228 / 962 899-52
> Fax: +49 (0)228 / 962 899-57
> adams at terrestris.de http://www.terrestris.de
> Amtsgericht Bonn, HRA 6835
> Komplementärin:
> terrestris Verwaltungs GmbH
> vertreten durch:
> Hinrich Paulsen, Till Adams
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
