[OpenLayers-Users] map paning issue
bartvde at osgis.nl bartvde at osgis.nl
Tue Sep 29 02:05:23 EDT 2009
You can use as much of plain ExtJS in your application as you want when
using GeoExt.
Best regards,
Bart
> hi Bart,
> Thanx for that tip.I had already gone through that.i deliberately chose to
> not use GeoExt since  i want to use more of plain Ext.Since i am afraid
> that
> many of the luxouries  of Ext might not be available in GeoExt I am
> looking
> to implement the zoom slider using simple Ext js.Is there any other go?
> regards
> sumith
> http://n2.nabble.com/map-paning-issue-tp3733917p3733955.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
