[OpenLayers-Users] TileCache and Openlayers
Rahn Hanno (rahn) rahn at zhaw.ch
Wed Sep 30 07:43:22 EDT 2009
I will realise the Tilecache but it doesn't work with my base layer. For all other layers it works.
Hello list,
I have another question and perhaps somebody can help me. I try to use Tilecache for a better performance of my maps.
I try to realise it, but in this time it will only work for my background layers. For my base Layer it doesn^t work.
For my base layer (only polygons, "gemeinden_2008") I write the follwing code in the tilecache.cfg.
[gemeinden_2008]
type=WMS
url=http://webgis.hsw.ch/cgi-bin/mapserv.exe?map=C:/ms4w/Apache/htdocs/GINES/Maps/Gemeinden_Bern.map
mapfile=C:/ms4w/Apache/htdocs/GINES/Maps/Gemeinden_Bern.map
layers=gemeinden_2008
extension=png
extent_type=loose
srs=EPSG:21781
bbox=555100,129900,678450,245000
metaTile=true
And in my OpenLayers File I define the layer like this:
var layerName = (jahr <=2008) ? 'gemeinden_2008' : 'gemeinden_2009';
var urlArrayTC = ["http://webgis.hsw.ch/cgi-bin/tilecache/tilecache.cgi?"];
var mapFile = "../htdocs/GINES/Maps/Gemeinden_Bern.map";
var options1 = {
                        maxExtent: new OpenLayers.Bounds(555100,129900,678450,245000),
                        maxScale: '500',
                        minScale: '458262',
                        //                      fractionalZoom: true,
                        resolutions:[481.8359375, 240.91796875, 120.458984375, 60.2294921875, 30.11474609375, 15.057373046875, 7.5286865234375, 3.76434326171875, 1.882171630859375, 0.9410858154296875, 0.47054290771484375, 0.23527145385742188, 0.11763572692871094, 0.058817863464355469, 0.029408931732177734, 0.014704465866088867, 0.0073522329330444336, 0.0036761164665222168, 0.0018380582332611084, 0.0009190291166305542],
                        //                      tileSize: new OpenLayers.Size(500,500),
                        units: 'm',
                        projection: "EPSG:21781",
                        controls: []
var map = new OpenLayers.Map('map',options1);
var wms = new OpenLayers.Layer.WMS("Gemeinden",urlArrayTC, {map:mapFile,layers:layerName,format:"image/png",EXCEPTIONS:"application/vnd.ogc.se_inimage"} );
var sld_string=url+"jahr="+jahr+"&indikator="+indikator1+"&klassen="+klassen+"&vis="+vis+"&fusion="+jahr4+"&farbe="+farbe;
wms.mergeNewParams({ SLD:sld_string});
I only get a white map without any polygons. Perhaps you can give me a little tip. I don't know Why I have no map data.
A lot of thanks
Hanno Rahn
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090930/dca0fbf1/attachment.html
