[OpenLayers-Users] Further to openlayers, IE8 and local files.
christopher.schmidt at nokia.com
Fri Apr 16 07:33:54 EDT 2010
On Apr 15, 2010, at 9:49 PM, ext Phil Scadden wrote:
> If I change XMLHttpRequest to
> function cXMLHttpRequest() {
> if (window.location.protocol == "file:") {
> this._object = new
> window.ActiveXObject('Microsoft.XMLHTTP');
> } else {
> this._object = oXMLHttpRequest ? new oXMLHttpRequest :
> new window.ActiveXObject('Microsoft.XMLHTTP');
> then the code works in IE8. (Obviously doesnt in FF - I am hoping
> someone better in JS can fix this up).
> The fix need to work for requests are going to both web and file
> (could
> have layers from both). jQuery's structure seems good for this.
It is not possible to make XMLHttpRequest requests from file:
locations in modern versions of Firefox. This is a security
restriction, and I am not aware of any way around it. If you want
something that works from a USB stick and works across all browsers, I
recommend including a local web server and serving files from that.
The http://labs.metacarta.com/on-a-stick/ distribution includes a
setup that does this.
-- Chris
