[OpenLayers-Users] MousePosition displayProjection
problem ortho->epsg:4326
Mike Adair
madair at dmsolutions.ca
Wed Apr 21 09:39:36 EDT 2010
Heiko,
The problem might be that the implementation of the ortho code in
Proj4js hasn't been validated yet (see the bottom of this page
http://trac.osgeo.org/proj4js/wiki/UserGuide). However there is a bug
report with a proposed fix in the trac system
(http://trac.osgeo.org/proj4js/ticket/42) that I haven't got to
implementing and testing yet.
Mike
Heiko Schröter wrote:
> Hello,
> i have a problem with the MousePosition Control. The relevant code snippets are as follows:
> Proj4js.defs["EPSG:4326"] = "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs";
> Proj4js.defs["EPSG:0815"] = "+proj=ortho +lon_0=0 +lat_0=90";
> Proj4js.defs["EPSG:0816"] = "+proj=ortho +lon_0=0 +lat_0=-90";
> var myoptions = {
> eventListeners: {
> "changebaselayer": hd_mapBaseLayerChanged
> units: "dd",
> maxResolution: 'auto',
> maxExtent: new OpenLayers.Bounds(-180,-90,180,90),
> controls: [
> new OpenLayers.Control.PanZoom(),
> new OpenLayers.Control.Navigation(),
> new OpenLayers.Control.MousePosition({"numDigits": 2,
> displayProjection: new OpenLayers.Projection("EPSG:4326")}),
> new OpenLayers.Control.LayerSwitcher({"ascending": true}),
> new OpenLayers.Control.Attribution()
> numZoomLevels: 5
> map = new OpenLayers.Map('map', myoptions);
> The MousePosition works ok in EPSG:4326. Changing to 0815/0816 stalls the output of the MousePosition. Changing back to EPSG:4326 everything is ok again.
> Omitting the "displayProjection" Option displays the MousePosition in meters in the 0815/0816 projection and in degrees in EPSG:4326 projection.
> So what i want is to display the MousePosition in "degrees" in the 0815/0816 projection as in EPSG:4326.
> As far as i understand the docs the transformation should be done automatically when proj4js is used.
> What do i do wrong ?
> Thanks and Regards
> Heiko
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Michael Adair
Senior Software Architect
DM Solutions Group Inc.
Office: (613) 565-5056 x26
http://www.dmsolutions.ca
http://research.dmsolutions.ca
