[OpenLayers-Users] Bing maps with dynamic resized map bug
Jimmy Aumard
jimmy.aumard at gmail.com
Thu Apr 22 04:56:05 EDT 2010
I have try to make an example :
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="content-type" content="text/html; charset=utf-8" />
<title>OpenLayers</title>
<script src='
http://maps.google.com/maps?file=api&v=2&key=AZERAAAAbsmHETfVBBkfYg-JOma8IhRLLSF_UQf1WG5vAu5MHZHm0uNmSxSASAYqpbkiQpo160A-r5z5xWFQtw
'></script>
<script src="
http://api.maps.yahoo.com/ajaxymap?v=3.0&appid=euzuro-openlayers"></script>
<script src='http://dev.virtualearth.net/mapcontrol/mapcontrol.ashx?v=6.1
'></script>
<!-- <script src="OpenLayers-2.8/lib/OpenLayers.js"></script>-->
<script src="http://openlayers.org/api/2.9-rc3/OpenLayers.js"></script>
<script type='text/javascript'>
var map;
// increase reload attempts
OpenLayers.IMAGE_RELOAD_ATTEMPTS = 3;
* Initialise la map, les couches, les evenements...
* @return void
function init() {
var usrbounds = new OpenLayers.Bounds(-1433917.9163166,
5014554.4359391,2167713.3877521, 6882716.1409359);
var options = {
projection : new OpenLayers.Projection("EPSG:900913"),
displayProjection : new OpenLayers.Projection("EPSG:4326"),
units : "m",
// restrictedExtent : usrbounds,
numZoomLevels : 18,
maxResolution : 156543.0339,
maxExtent : new OpenLayers.Bounds(-20037508, -20037508, 20037508,
20037508.34),
controls : [ new OpenLayers.Control.Navigation(),
new OpenLayers.Control.MousePosition(),
new OpenLayers.Control.LayerSwitcher() ]
map = new OpenLayers.Map('map', options);
// create Google Mercator layers
var gmap = new OpenLayers.Layer.Google("google_str", {
'sphericalMercator' : true
var gsat = new OpenLayers.Layer.Google("google_sat", {
type : G_SATELLITE_MAP,
'sphericalMercator' : true,
numZoomLevels : 22
var ghyb = new OpenLayers.Layer.Google("google_hyb", {
type : G_HYBRID_MAP,
map.addLayers( [ gmap, gsat, ghyb ]);
// create Virtual Earth layers
var veroad = new OpenLayers.Layer.VirtualEarth("bing_str", {
'type' : VEMapStyle.Road,
var veaer = new OpenLayers.Layer.VirtualEarth("bing_sat", {
'type' : VEMapStyle.Aerial,
var vehyb = new OpenLayers.Layer.VirtualEarth("bing_hyb", {
'type' : VEMapStyle.Hybrid,
map.addLayers( [ veroad, veaer, vehyb ]);
// create Yahoo layer
var yahoo = new OpenLayers.Layer.Yahoo("yahoo_str", {
var yahoosat = new OpenLayers.Layer.Yahoo("yahoo_sat", {
'type' : YAHOO_MAP_SAT,
var yahoohyb = new OpenLayers.Layer.Yahoo("yahoo_hyb", {
'type' : YAHOO_MAP_HYB,
map.addLayers( [ yahoo, yahoosat, yahoohyb ]);
// create OSM layer
var mapnik = new OpenLayers.Layer.OSM("osm");
var osmarender = new OpenLayers.Layer.OSM("osm_tile",
"http://tah.openstreetmap.org/Tiles/tile/${z}/${x}/${y}.png
map.addLayers( [ mapnik, osmarender ]);
//map.setBaseLayer(veaer);
map.zoomToExtent(usrbounds, true);
* Passer du plein ecrant a une taille fixe
* @return void
function togglePleinEcran() {
var height =document.getElementById('carte').style['height'];
if (height != "600px") {
document.getElementById('carte').style['width']='1000px';
document.getElementById('carte').style['height']='600px';
} else {
document.getElementById('carte').style['width']='600px';
document.getElementById('carte').style['height']='400px';
map.updateSize();
</script>
</head>
<body onload="init()" id="api">
<div id="carte" style="width: 800px; height: 600px">
<div id="map" style="width: 100%; height: 100%"></div>
</div>
1 Change the size <br/>
2 Change layer to bing layer.<br/>
3 Changer the size again and go to google map, normally you have bug (if you
doesn't bug test steps again)<br/><br/>
Another bug when you are on google map and switch to bing map the zoom is
not the same<br/>
1 go to google map <br/>
2 go to bing map <br/>
Sometimes the zoom is not the same, make step again if the bug is not
going<br/>
<input class="button" type="button" value="Change size"
onclick="togglePleinEcran();" />
</body>
</html>
Hope that show you the issue.
Cheers.
Jim
2010/4/22 Andreas Hocevar <ahocevar at opengeo.org>
> On Apr 22, 2010, at 09:25 , Jimmy Aumard wrote:
> > Hello,
> > I have test the 2.9 RC3 version of OpenLayers and I have always the bugs
> if I show a bing map, resize the map and change layer to google map. the
> google map object was not resized.
> Please provide a minimal example that shows the issue.
> Regards,
> Andreas.
> > Thanks
> > Jim
> > 2010/4/20 Jimmy Aumard <jimmy.aumard at gmail.com>
> > Yes I use OpenLayers 2.8 because it is the stable version, I have same
> problem with Google map and I resolved this with
> > map.getLayersBy('name','google_str')[0].mapObject.checkResize();
> > I will test the 2.9 version.
> > Thanks.
> > Jim
> > 2010/4/19 Andreas Hocevar <ahocevar at opengeo.org>
> > On Apr 19, 2010, at 17:54 , Jimmy Aumard wrote:
> > > Thanks!!
> > > I have find another solution :
> > > map.getLayersBy('name','bing_str')[0].mapObject.Resize(500,500);
> > > I resize the bing map object for each layer and it's works.
> > Oh, in that case I assume you are still using OpenLayers 2.8? This is
> fixed in 2.9 (see http://trac.openlayers.org/ticket/2285).
> > -Andreas.
> > Aumard Jimmy
> > Développeur
> > KINAXIA
> > c/o CICA / PacaEst
> > 2229 Route des Crêtes
> > F-06560 Sophia Antipolis
> > Tél.: +33 (0)4 8973 0242
> > Mob.: +33 (0)6 6017 2827
> > Fax : +33 (0)4 8307 6583
> > http://www.kinaxia.fr
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
Aumard Jimmy
Développeur
KINAXIA
c/o CICA / PacaEst
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100422/e6feada0/attachment.html
