[OpenLayers-Users] Possibility to put a tiled image on OpenLayers
Jimmy Aumard jimmy.aumard at gmail.com
Fri Apr 23 10:45:18 EDT 2010
Hay,
I have explore the example who giving to me (
http://toxic.berkeley.edu/~bpederse/genome-browser/<http://toxic.berkeley.edu/%7Ebpederse/genome-browser/>)
and it have 'bp' on unit
And I want to know if it's possible ( and how ) to put pixel in units for
the map?
My tiles are show correctly but I have to put an marker (vector feature) to
x% and y% to the size image but if my unit is degrees and projection WGS84 I
don't think it's possible :s
Thanks!
Jim
2010/4/22 David Fawcett <david.fawcett at gmail.com>
> Jimmy,
> If you want to overlay your images with other geographic data, I think that
> the first step that you will need to do is to georeference your images.
> If you want to use arbitrary image coordinates, you might want to look at
> these user examples:
> http://trac.openlayers.org/wiki/Gallery#Non-MapBrowsing
> http://www.andrewlarcombe.co.uk/index.php/bruggepano
> David.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100423/667f7a44/attachment.html
