[OpenLayers-Users] Selecting Feature Trouble
Snoosel mario.schedler at web.de
Sun Apr 25 07:02:54 EDT 2010
during the last weeks I have created a small Web-Map using OpenLayers, ExtJs
and GeoExt. When clicking a tree element some points will be dispalyed in
the map and the Extent will be changed related to the data extent.
When selecting a point the point will be highlighted and a message will be
displayed using alert(). As soon as I select another point the first point
is still highlighted. Does anybody has a solution why this happens. I tried
to figure it out but I'm not successful.
Thanks, Mario
Code:
Ext.onReady(function(){
	var map = new OpenLayers.Map();
    var wmsLayer = new OpenLayers.Layer.WMS(
        "vmap0",
        "http://labs.metacarta.com/wms/vmap0",
        {layers: 'basic'}
    var vecLayer = new OpenLayers.Layer.Vector("vector");
    map.addLayers([wmsLayer, vecLayer]);
	vecLayer.setVisibility(false);
	var selectControl = new OpenLayers.Control.SelectFeature(vecLayer, {
		toggle: true,
		clickout: true
	map.addControl(selectControl);
	selectControl.activate();
	var tmpLayer;
	store = new GeoExt.data.FeatureStore({
        layer: vecLayer,
        fields: [
            {name: 'name', type: 'string'},
			{name: 'id', type: 'string'}
        proxy: new GeoExt.data.ProtocolProxy({
            protocol: new OpenLayers.Protocol.HTTP({
                url: "point.asp",
                format: new OpenLayers.Format.GML()
		autoLoad: true
	Ext.app.PositionLoader = Ext.extend(Ext.ux.tree.XmlTreeLoader, {
	    processAttributes : function(attr){
	        if(attr.cname){
	            attr.text = attr.cname;
	            attr.iconCls = 'author-' + attr.gender;
	            attr.loaded = true;
	            attr.expanded = true;
	        } else
	        if(attr.sname){
				attr.text = attr.sname;
				attr.iconCls = 'book';
				attr.loaded = true;
	        } else
	        if(attr.pname){
	            attr.text = attr.pname;
	            attr.loaded = true;
	        } else
	        if(attr.aname){
	            attr.text = attr.aname;
	            attr.loaded = true;
				attr.leaf = true;
	var detailsText = 'Select';
	var tpl = new Ext.Template(
		'<h2 class="title">{scanname}</h2>',
		'<p>Id: {id}</p>',
		'<p>Name: {innerText}</p>',
		'<p> {url} Link </p>'
	tpl.compile();
	var tplArea = new Ext.Template(
		'<h2 class="title">{aname}</h2>'
	tplArea.compile();
	new Ext.Panel({
		title: 'Location',
		renderTo: 'tree',
		layout: 'border',
		width: 800,
		height: 700,
		items: [{
			xtype: 'treepanel',
			region: 'center',
			margins: '2 2 0 2',
			animate: true,
			autoScroll: true,
			rootVisible: false,
			root: new Ext.tree.AsyncTreeNode(),
			loader: new Ext.app.PositionLoader({
				dataUrl:'point.asp'
			listeners: {
				'render': function(tp){
					tp.getSelectionModel().on('selectionchange', function(tree, node){
						var el = Ext.getCmp('details-panel').body;
						if (node && node.leaf) {
							if (Ext.isObject(tmpLayer)) {
								map.removeLayer(tmpLayer);
								tmpLayer.destroyFeatures();
								tmpLayer.destroy();
							//Creating the new Store
							tmpLayer = new OpenLayers.Layer.Vector("Laser Scanning Positions", {
								eventListeners: {
									'featuresadded': function(feature){
										var extent = tmpLayer.getDataExtent();
										map.zoomToExtent(extent);
									'featureselected': function(event){
										var feature = event.feature;
										var detail = feature.attributes['name'];
										alert(feature.id);
							map.addLayer(tmpLayer);
							tmpStore = new GeoExt.data.FeatureStore({
								layer: tmpLayer
							var id = node.attributes.text + node.parentNode.attributes.text +
							node.parentNode.parentNode.attributes.text +
							node.parentNode.parentNode.parentNode.attributes.text;
							// Filter
							store.filter('id', id, true, true);
							//Adding records to tmpStore
							for (i = 0; i < store.getCount(); i++) {
								var record = store.getAt(i);
								tmpStore.add(record);
			region: 'south',
			title: 'Location Details',
			autoScroll: true,
			collapsible: true,
			split: true,
			margins: '0 2 2 2',
			cmargins: '2 2 2 2',
			height: 220,
			html: detailsText
			region: 'east',
			title: "Map",
			xtype: "gx_mappanel",
			map: map,
			split: true,
			width: 580,
			margins: '0 0 5 0'
Image:
http://n2.nabble.com/forum/FileDownload.jtp?type=n&id=4958044&name=Map.png
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Selecting-Feature-Trouble-tp4958044p4958044.html
