[OpenLayers-Users] How to print map area with openlayers
guillaumev guillaume at viguierjust.com
Thu Apr 29 14:58:22 EDT 2010
I still wasn't able to solve that problem. Basically, what happens is that
if I move through the map, then do a zoom out and then a zoom in, the map is
printed at the position where I moved to. However, if I just move through
the map, without doing a zoom out and zoom in, the map is printed in its
initial position (the position before moving through it). Any thoughts on
that ?
Thank you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/How-to-print-map-area-with-openlayers-tp4901023p4981714.html
