[OpenLayers-Users] IE6 / OpenLayers / Path DrawFeature and
DoubleClicks
James.Sewell at lisasoft.com
Fri Apr 30 02:23:55 EDT 2010
Greetings,
I am working with OpenLayers and IE6 (which is the required SOE for the project) and have noticed that mouse doubleclicks are not being captured correctly when drawing a Path from an OpenLayers.Control.DrawFeature if another element is drawn to any layer from a sketchmodified event.
>From IE in the above situation the Path is drawn (which has a circle dynamically drawn round it using the sketchmodified event to call the OpenLayers.Layer.Vector.addFeatures method) but requires a single click immediately followed by a double click to terminate the Path.
If the addFeatures call is not made (the circle is not drawn ) behavior is as normal. The code works as expected in Chrome.
Has anyone dealt with this behavior before? Any help would really be appreciated.
Cheers,
James Sewell
LISAsoft Developer
+61 (3) 8680 3200 / +61 414 688 892
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100430/99d6a038/attachment.html
