[OpenLayers-Users] mergeNewParams + Legend
Andreas Hocevar ahocevar at opengeo.org
Thu Aug 5 11:57:55 EDT 2010
I am pretty sure that the request URI is too long. What you could do is reconfigure the legend type selection sequence, so a VectorLegend rather than a WMSLegend is created. A prerequisite is this non-API hack though:
GeoExt.VectorLegend.supports = function(layerRecord) {
    return layerRecord.get("layer").styleMap;
This will tell VectorLegend that it supports all layers that have a styleMap.
Now you can go ahead and create your legendPanel like this:
var legendPanel = new GeoExt.LegendPanel({
    preferredTypes: ["gx_vectorlegend"]
Finally, when creating your WMS layer with the SLD_BODY (and before you do mergeNewParams), you have to give the WMS layer a StyleMap with a "default" render intent, which you have to give the style object of your SLD.
Regards,
Andreas.
On Aug 5, 2010, at 17:45 , Sascha Müller wrote:
> Hi,
> I tried this SLD with only two instead of five rules. It works.
> Could it be, that the request 'GetLegendGraphic' is too long with the
> SLD inside?
> Like mergeNewParams() without 'Post'  in 'OpenLayers.Layer.WMS'.
> Is there a way to implement it?
> Or is this more a GeoServer thing?
> Sascha
>> Hi,
>> I use:
>> GeoExt: trunk (Revision: 2257)
>> OpenLayers: 2.9
>> GeoExt: 3.2.1
>> GeoServer: 1.7.7
>> I use mergeNewParams() to change the Style of a layer. This approach
>> works except for one layer.
>> This layer contains five rules with filter. The map changes after
>> mergeNewParams(), the legend not.
>> The layername is still there, the images of the five rules are gone.
>> If I use this SLD (see below) for the layer with the GeoServer from
>> start, the layer appears in map and legend. only after
>> mergenewParams() the layer appears not in the legend.
>> The layer uses this:  var addlayer = new OpenLayers.Layer.WMS.Post()
>> SLD
>> <?xml version="1.0" encoding="UTF-8"?>
>> <sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld"
>> xmlns:sld="http://www.opengis.net/sld"
>> xmlns:ogc="http://www.opengis.net/ogc"
>> xmlns:gml="http://www.opengis.net/gml" version="1.0.0">
>> <sld:NamedLayer>
>> <Name>WL:UBahn</Name>
>> <sld:UserStyle>
>> <sld:Name>Default Styler</sld:Name>
>> <sld:Title/>
>> <sld:FeatureTypeStyle>
>> <sld:Name>name</sld:Name>
>> <sld:FeatureTypeName>Feature</sld:FeatureTypeName>
>> <sld:SemanticTypeIdentifier>generic:geometry</sld:SemanticTypeIdentifier>
>> <sld:SemanticTypeIdentifier>colorbrewer:unique:oranges</sld:SemanticTypeIdentifier>
>> <sld:Rule>
>> <sld:MinScaleDenominator>0</sld:MinScaleDenominator>
>> <sld:MaxScaleDenominator>100000000</sld:MaxScaleDenominator>
>> <sld:Name>rule01</sld:Name>
>> <sld:Title>U1</sld:Title>
>> <Filter>
>> <PropertyIsEqualTo>
>> <PropertyName>LINIE</PropertyName>
>> <Literal>U1</Literal>
>> </PropertyIsEqualTo>
>> </Filter>
>> <sld:LineSymbolizer>
>> <sld:Stroke>
>> <sld:CssParameter name="stroke">
>> <Literal>#FEEDDE</Literal>
>> </sld:CssParameter>
>> <sld:CssParameter name="stroke-linecap">
>> <Literal>butt</Literal>
>> </sld:CssParameter>
>> <sld:CssParameter name="stroke-linejoin">
>> <Literal>miter</Literal>
>> </sld:CssParameter>
>> <sld:CssParameter name="stroke-opacity">1</sld:CssParameter>
>> <sld:CssParameter name="stroke-width">3</sld:CssParameter>
>> <sld:CssParameter name="stroke-dashoffset">
>> <Literal>0</Literal>
>> </sld:CssParameter>
>> </sld:Stroke>
>> </sld:LineSymbolizer>
>> </sld:Rule>
>> <!-- The other RULSs looks the same like the one above -->
>> </sld:FeatureTypeStyle>
>> </sld:UserStyle>
>> </sld:NamedLayer>
>> </sld:StyledLayerDescriptor>
>> Is there something wrong with the SLD? Do I have something to consider
>> if I use mergeNewParams(), or something with the Legend?
>> Thanks
>> Sascha
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
