[OpenLayers-Users] open layers with ER mapper or erdas image web server possible??
Imran Rajjad rajjad at gmail.com
Fri Aug 6 08:40:55 EDT 2010
hi,
thanks for responding, actually I`m already set on geoserver for
feature data, however the image has been slowing things down, so i was
hoping to slip in a layer only dedicated to satellite imagery from an
imaging server. now if i override this function, it will also change
for wms requests from geoserver, would'nt that be a problem?
regards,
Imran
On Fri, Aug 6, 2010 at 5:35 PM, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> OpenLayers works fine with ERMapper. You can use Layer.WMS, the only caveat is that you might have to override the getURL method:
> getURL: function(bounds) {
>  // ermapper does not like UTF8 URIs
>  var url = OpenLayers.Layer.WMS.prototype.getURL.apply(this, arguments);
>  return decodeURIComponent(url);
> Regards,
> Andreas.
> On Aug 6, 2010, at 13:39 , Imran Rajjad wrote:
>> Hi list,
>> does open layers work with er mapper or erdas image web server? I have
>> been setting up a design and i have selected erdas for image mapping
>> though I am not sure if open layer can work with them since I have
>> never come across any example or information. any links would be
>> appreciated.
>> thanks
>> regards,
>> Imran
>> I.R
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Andreas Hocevar
> OpenGeo - http://opengeo.org/
> Expert service straight from the developers.
I.R
