[OpenLayers-Users] clickTolerance on selectFeature?
Alex Brandsen
alex.brandsen at gmail.com
Fri Aug 6 12:44:50 EDT 2010
Yeah, apparently.. Do you (or anyone else) know how to create a similar
effect with selectFeature then?
Alex.
Date: Wed, 04 Aug 2010 11:02:01 -0400
Subject: Re: [OpenLayers-Users] clickTolerance on selectFeature?
To: users at openlayers.org
Message-ID: <4C5980E9.4000701 at mapgears.com
Content-Type: text/plain; charset="iso-8859-1"
Alex,
My bad. the 'clickTolerance' of the GetFeature control has not the
same purpose as the 'clickTolerance' of the Feature Handler :
http://dev.openlayers.org/docs/files/OpenLayers/Handler/Feature-js.html#OpenLayers.Handler.Feature.clickTolerance
Regards,
Alexandre
On 10-08-04 10:36 AM, Alex Brandsen wrote:
> Hi Alexandre,
> thanks for your reply! I tried using
> OpenLayers.Handler.Feature.prototype.clickTolerance=100/1000/1000000;
> , but it makes no difference. It does get stored, because when I do
> alert(OpenLayers.Handler.Feature.prototype.clickTolerance); it does
> show the correct value.
> I also tried altering the clickTolerance in openlayers.js, but that
> didn't do anything either.
> Thanks,
> Alex.
> Date: Tue, 03 Aug 2010 08:12:00 -0400
> From: Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
> To: users at openlayers.org <mailto:users at openlayers.org>
> Message-ID: <4C580790.3030102 at mapgears.com
> <mailto:4C580790.3030102 at mapgears.com>
> Hi Alex,
> 'clickTolerance' is a OpenLayers.Handler.Feature property. If you
> look in the Select.js file, you'll see that the handler is set inside
> the initialize method and that there is no way other than modifying the
> code there to set your own 'clickTolerance'. A thing you could do is to
> overwrite its default value to what you want but it will affect every
> other Controls that use it (do it before defining your SelectFeature
> control ) :
> OpenLayers.Handler.Feature.prototype.clickTolerance = 100;
> Try it and tell me if that worked for you.
> Kind regards,
> Alexandre
> On 10-08-02 04:40 PM, Alex Brandsen wrote:
> > Hi all,
> > is it possible to set the clickTolerance on a selectFeature control? I
> > can find the clickTolerance on the getFeature control :
http://dev.openlayers.org/docs/files/OpenLayers/Control/GetFeature-js.html#OpenLayers.Control.GetFeature.clickTolerance
> > but not in the documentation of selectFeature. If I just try to add
> > "clickTolerance: 100" to the options array of selectFeature it has no
> > effect...
> > Thanks,
> > Alex.
> > Users mailing list
> > Users at openlayers.org <mailto:Users at openlayers.org>
> > http://openlayers.org/mailman/listinfo/users
> Alexandre Dub?
> Mapgears
> www.mapgears.com <http://www.mapgears.com/>
> Users mailing list
Alexandre Dub?
Mapgears
www.mapgears.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100806/6e515e26/attachment.html
