[OpenLayers-Users] Can I output my layers/map in SVG?
Ian Turton ijturton at gmail.com
Fri Aug 6 18:34:31 EDT 2010
On Fri, Aug 6, 2010 at 6:18 PM, Adam Ratcliffe <adam at prema.co.nz> wrote:
> If your map server also provides a WFS service, such as GeoServer does, you can fetch your map features as structured data and render them as vectors on the client.  You can see an example here: http://openlayers.org/dev/examples/
Or you could set the format of a WMS request to svg in a GeoServer
request. See the layers previews for an example.
Ian
Ian Turton
