[OpenLayers-Users] export map components to an image
Imran Rajjad rajjad at gmail.com
Wed Aug 11 00:38:12 EDT 2010
thanks adam, though I`m using GS 1.7.7 , this feature I suppose is in GS 2.0.x
regards,
Imran
On Wed, Aug 11, 2010 at 12:52 AM, Adam Ratcliffe <adam at prema.co.nz> wrote:
> If you're serving your feature data from GeoServer you could take a look at the Print module: http://geoserver.org/display/GEOS/Printing+2.0+HOWTO
> Cheers
> Adam
> On 11/08/2010, at 12:02 AM, Imran Rajjad wrote:
>> Hi list,
>> I was wondering if it is possible to export the map view to an image,
>> for example, if my map is showing certain layers and over them I have
>> a vector layer , I want to export the features visible in the map to
>> an image file, now I figured that out for wms layers, we can simply
>> make a wms request embedding all the visible layers in respected
>> orders along with the visible map extent, but this approach does not
>> work for features inside a vector layer, any ideas or some links would
>> be appreciated.
>> regards,
>> Imran
>> I.R
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
I.R
