[OpenLayers-Users] Some help with persistent layers and web server
	reponses.
    Nathan Silver
    nsilver at imagesensingca.com
    Wed Aug 11 11:42:01 EDT 2010
Hello all,
I've looked at  Peter Robbins' example of a persistent layer using GeoJSON
(http://maps.peterrobins.co.uk/files/ol6.html) which is well behaved. I've
been trying to duplicate the entire structure. I have my own IIS 7.5 running
on Windows 7 which in turn is connected to a SQL Server 2008 DB. Once I can
get OpenLayers to send the right query to IIS, I'll be away to the races.
Here's what's confounding me.
The working example issues a GET to retieve the GeoJSON data. The vector
layers is defined like this:
var vectorLayer = new OpenLayers.Layer.Vector("Line Vectors", {
styleMap: sm,
eventListeners: {
 "featuresadded": dataLoaded
strategies: [
new OpenLayers.Strategy.Fixed(),
saveStrategy
protocol: new OpenLayers.Protocol.HTTP({
url: "/cgi-bin/fs/workspace/",
format: new OpenLayers.Format.GeoJSON({
ignoreExtraDims: true,
internalProjection: map.baseLayer.projection,
externalProjection: wgs84
My code only issues an OPTIONS request to the web server, something the
working example never does. If I step through the OpenLayers code with
Firebug, not only do I not see the OPTIONS request, I don't see anything
hitting the webserver at all. My vector layer is defined like this:
var vectors = new OpenLayers.Layer.Vector("Vector Layer", {
style: {
strokeColor: "blue",
                                strokeWidth: 3,
                                cursor: "pointer"
eventListeners: {
                strategies: [
                                saveStrategy
                                url: "http://10.0.1.26/roads.aspx",
                                                internalProjection:
If someone can help me understand why OpenLayers is requesting "OPTIONS"
from the server (which I can't even see from grepping  or stepping through
the code), and what I might need to go in order to get these two piece glued
together, I would really appreciate it.
Many thanks in advance,
Nathan Silver
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100811/312e2610/attachment.html
