[OpenLayers-Users] WFS: Problem retrieving Features from Geoserver/PostGIS
Bart van den Eijnden bartvde at osgis.nl
Thu Aug 12 03:31:55 EDT 2010
use:
featureType: "ogm_polygons",
featurePrefix: "OpenGeoMap"
alternatively, specify featureNS instead of featurePrefix. That's the namespace which is bound by Geoserver to the OpenGeoMap prefix.
Best regards,
Bart
Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
OSGIS
bartvde at osgis.nl
On Aug 12, 2010, at 9:24 AM, andreia farrér wrote:
> Dear List,
> I am trying to modify the wfs-editor.html-example for digitizing Points, Lines and Polygons. First I created a polygon-shapefile (one polygon in it, extending a big part of eastern Switzerland) in QGIS and imported it into my PostGIS-DB as "ogm_polygons"; then I published the layer in Geoserver. Now I would like to show the polygon-features in my map which somehow doesn't function.
> Here an extract of my code:
> Ext.BLANK_IMAGE_URL = "../ext/resources/images/default/s.gif";
>         Ext.onReady(function() {
>             OpenLayers.ProxyHost = "../cgi-bin/proxy.cgi?url=";
> var saveStrategy = new OpenLayers.Strategy.Save({
>                 onCommit: function() {
>                     saveStrategy.ogm_polygons.refresh();
> var ogm_polygons = new OpenLayers.Layer.Vector("polygons",{
>                 strategies: [new OpenLayers.Strategy.Fixed(), saveStrategy],
>                 protocol: new OpenLayers.Protocol.WFS({
>                     url: "http://localhost:8090/geoserver/wfs",
>                     featureType: "OpenGeoMap:ogm_polygons",
>                     geometryName: "the_geom",
>                     srsName: "EPSG:21781",
>                     maxExtent: new OpenLayers.Bounds(140000, -240000, 1380000, 580000)
> var map_options = {maxExtent: new OpenLayers.Bounds(484000, 63000, 835000, 296000),
>                 numZoomLevels: 12, maxScale: 5000, minScale: 2000000, units: 'm',  projection: 'EPSG:21781'};
>             var map = new OpenLayers.Map(map, map_options,{
>                 allOverlays: true
> map.addLayer(ogm_polygons);
> Unfortunately the Layer won't show in my Mapwindow. If i fire up HttpFox and check the POST-Statement I get the following message:
> <wfs:FeatureCollection xsi:schemaLocation="OpenGeoMap http://localhost:8090/geoserver/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=OpenGeoMap%3Aogm_polygons http://www.opengis.net/wfs http://localhost:8090/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd">
> <gml:boundedBy>
> <gml:null>unknown</gml:null>
> </gml:boundedBy>
> <gml:featureMember>
> <OpenGeoMap:ogm_polygons fid="ogm_polygons.1">
> <OpenGeoMap:bezeichnun>test</OpenGeoMap:bezeichnun>
> <OpenGeoMap:litho_01>l1</OpenGeoMap:litho_01>
> <OpenGeoMap:the_geom>
> <gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg.xml#21781">
> <gml:polygonMember>
> <gml:Polygon>
> <gml:outerBoundaryIs>
> <gml:LinearRing>
> <gml:coordinates decimal="." cs="," ts=" ">
> 47701.85817123,185193.40602232 120638.63788536,378756.39834058 328227.9339948,448887.91729647 328227.9339948,448887.91729647 317006.89096185,78593.49720937 47701.85817123,185193.40602232
> </gml:coordinates>
> </gml:LinearRing>
> </gml:outerBoundaryIs>
> </gml:Polygon>
> </gml:polygonMember>
> </gml:MultiPolygon>
> </OpenGeoMap:the_geom>
> </OpenGeoMap:ogm_polygons>
> </gml:featureMember>
> </wfs:FeatureCollection>
> In my eyes this looks totally fine, but I'm absolutely clueless why the feature won't show in my Map!
> Has anybody any idea on what I'm doing wrong?
> Any help is greatly appreciated; many thanks already in advance!
> Sincerely
> Andreia
> Andreia Farrér, Birmensdorferstr. 260, 8055 Zürich; phone: +41 78 825 44 93
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100812/5e3efdf1/attachment.html
