[OpenLayers-Users] GeoTIFF display
Mickael BEAUFILS mickael.beaufils at acatus.fr
Thu Aug 12 05:38:43 EDT 2010
Hi Jon, Hi Andreas,
Thanks for your answer.
Well I never used the GeoServer REST API, but according to you it seems to be the solution.
I will have a close look to it and try this.
Regards,
Mickael Beaufils
De : mankillseverything at googlemail.com [mailto:mankillseverything at googlemail.com] De la part de Jon Britton
Envoyé : jeudi 12 août 2010 11:02
À : Mickael BEAUFILS
Objet : Re: [OpenLayers-Users] GeoTIFF display
Are you sure you can't use geoserver? I do something similar using the geoserver REST API to store my WPS output. I do this all programmatically from a Java servlet.
Jon
On 12 Aug 2010 08:47, "Mickael BEAUFILS" <mickael.beaufils at acatus.fr <mailto:mickael.beaufils at acatus.fr> > wrote:
> Hi everyone,
> I am creating some geoTIFF files via a WPS request and I would like to
> display them in an Openlayers framework.
> GeoServer enable to do this but not in a direct way (you have to put the
> files in geoserver data directory, config the access the file in the
> Geoserver admin page, ...).
> At this time, is there a solution to directly display a geoTIFF on
> OpenLayers ?
> Thanks for your help !
> Regards,
> MB
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100812/2481b6de/attachment.html
