[OpenLayers-Users] Displaying images even at the edgeof the screen
Tpi sykkel at gmail.com
Thu Aug 12 08:35:47 EDT 2010
Thanks to both of you, an image layer did what I wanted.
However the performance compared to using the feature, stylemap and point
went down by a huge amount. This worked with no lag prior to changing to an
image layer. Using the same code as Wippermann showed here, just of course
slightly modified for URL and bounds.
For reference, the image I use is getting scaled down, which I know isn't
optimal, but it worked fine when using an externalGraphic with it. It's a
transparent GIF that takes 55kB and is 1770x1426 pixels in size.
Dragging around on the map is now sloppy compared to working very well.
I guess I'll have to play around with it a bit more and hope to find
something to solve it with. :-)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Displaying-images-even-at-the-edge-of-the-screen-tp5329187p5415931.html
