[OpenLayers-Users] Bug? with SelectFeature,
Stylemap and strokeWidth=0.0 on IE 8
Andreas Hocevar
ahocevar at opengeo.org
Sat Aug 14 06:00:31 EDT 2010
if you don't want a stroke, you should use
stroke: false
rather than setting a zero strokeWidth or strokeOpacity.
Regards,
Andreas.
On Aug 14, 2010, at 06:17 , Michael Sephton wrote:
> I think I have found a bug in OpenLayers.
> It happens when you have a gml_layer, a selectFeature control applied to it, and a styleMap with different styles for default and select. Internet explorer does not behave in the expected way if the default select is specified with a strokeWidth of zero AND the select style has a strokeWidth=2.0 (or >0.0 probably).
> The problem is demonstrated in the following example (which works fine in Firefox but not in IE8):
> http://members.optusnet.com.au/~msephton/ol/gml-layer_h2.html
> A work around for this problem is to set the strokeWidth and strokeOpacity for the default style as 1.0 and 0.0 respectively, and the strokeOpacity for the select style as 1.0 (or >0.0 probably).
> The work around is demonstrated in this example:
> http://members.optusnet.com.au/~msephton/ol/gml-layer_h2b.html
> Should I file a ticket for this?
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
