[OpenLayers-Users] arcgis server 10
Sarah Schuessler sarah_flip at yahoo.de
Tue Aug 17 10:45:22 EDT 2010
Thanks for testing and suggestion!
I will check these different suggestions for our needs and report back then.
best regards
Sarah
Hi Sarah,
You can test OpenLayers with
http://resources.arcgis.com/content/arcgisserver/10.0/sample-gis-server-and-gis-services
ESRI's sample servers . I did a quick test on the
http://openlayers.org/dev/examples/arcgis93rest.html OpenLayers ArcGIS
Server 9.3 Rest API Example  and it appears to work fine with an ArcGIS
Server 10 Map Service
(http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/export).
Given the option however, I would most definitely go with a
GeoServer/PostGIS configuration.  There is much more documentation and code
samples for this setup and it just seems to work better in general.  I use
GeoServer for my key operational layers and bring in ArcGIS Server layers as
basemaps from ESRI, USGS, etc.
BRYAN
Bryan R. McBride, GISP
http://www.bryanmcbride.com bryanmcbride.com
http://geoserving.net/ geoserving.net
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/arcgis-server-10-tp5431309p5431998.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100817/e9b11d3d/attachment.html
