[OpenLayers-Users] LayerSwitcher - Panel show and disable layerentry
Jan Tappenbeck osm at tappenbeck.net
Fri Aug 20 07:13:25 EDT 2010
HI !
thanks for the message - and it work - look at:
http://www.tappenbeck.net/osm/maps/deu/index_new.php?id=1017
but can you tell me why firebugs write:
layer is not defined
[Break on this error] layer.setVisibility(false);
regards Jan :-)
Am 19.08.2010 15:09, schrieb BMcBride:
> To make the layerswitcher initially visible, you can do something like:
> map.addControl(new OpenLayers.Control.LayerSwitcher({'ascending':false}));
> var ls = map.getControlsByClass('OpenLayers.Control.LayerSwitcher')[0];
> ls.maximizeControl();
> To set layer visibility, you can do something like:
> Bryan R. McBride, GISP
> http://www.bryanmcbride.com bryanmcbride.com
> http://geoserving.net/ geoserving.net
