[OpenLayers-Users] LayerSwitcher - Panel show and disable layerentry - additional
Marc Jansen jansen at terrestris.de
Fri Aug 20 15:40:39 EDT 2010
Hi Jan,
looks as if you are still adding two LayerSwitcher Controls:
   1. in the Map-Constructor (new OpenLayers.Map(...))
   2. and one in line 219 (map.addControl(new
      OpenLayers.Control.LayerSwitcher());)
I'd suggest getting rid of the second one.
What exactly do you mean by deactivate the checkbox? Adding
displayInLayerSwitcher : false to a layers options-object will result in
a layer not being shon in the LayerSwitcher.
Regards,
Marc
Am 20.08.2010 16:37, schrieb Jan Tappenbeck:
> Am 20.08.2010 15:05, schrieb BMcBride:
>> OK- So it looks like you have several instances of the LayerSwitcher control
>> in your code (see lines 46, 62, 219). This is why it does not appear to hide
>> correctly.  Remove 2 of these controls and you should be all set.
>> As for your "layer not defined" error...  I was assuming that you were
>> trying to hide a layer when the map initially loads.  So if you wanted the
>> "Hofladen" layer to be initially hidden and unchecked, you would have to set
>> the layer as a variable and use setVisibility(false);.
>> var hofladen =  new OpenLayers.Layer.PopupMarker("Hofladen", {  ...
>> map.addLayer(hofladen);
>> hofladen.setVisibility(false);
>> Bryan R. McBride, GISP
>> http://www.bryanmcbride.com bryanmcbride.com
>> http://geoserving.net/ geoserving.net
> thanks for response.
> now i kill a double layers switch in
> http://www.tappenbeck.net/osm/maps/deu/index_new.php?id=1017
> but when you click "+" only an other layerpanel will show - like a
> overlay to the other. but i see no possiblity to hide the hole panel again !
> can you give me more detail because my englisch is not very well and i
> am a beginner of ol!!
> this was one question - the other is how to deactive a layer-checkbox in
> the panel by default ??!?!?
> can you help me more ??
> regards Jan :-)
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100820/f5671a68/attachment.html
