[OpenLayers-Users] Problem with LoadingPanel in IE8
Kalyan Kamepalli kalyan.kamepalli at gmail.com
Wed Aug 25 20:31:59 EDT 2010
 Bryan,
I now figured the problem. It's working fine with IE6. Unfortunately, I can
not test this on Firefox, Chrome or Safari as our development servers don't
have them installed. However for the last couple of days I have been testing
this on IE8 and that just didn't work. Surprisingly, it didn't show any
error messages in development tools of IE. I think some problem with CSS for
IE8. I just tested this on IE6 and that worked.
Any one else figured this problem before ? Are there any other problems with
IE8 ?
Just got another question here. I changed my image from loading.gif to some
picture.gif with wheel type image and that did turn up well.But, the problem
here is, it remained static where as in the case of loading.gif , it showed
that nice progressive status ( The green bar keep increasing ). How to make
my wheel like picture get rotating kind of feel ??
Any suggestions and ideas are greatly appreciated.
Cheers,
Kalyan.
  On Wed, Aug 25, 2010 at 10:54 PM, McBride, Bryan <
BMcBride at chacompanies.com> wrote:
>  Hi Kaylan,
> What errors are you getting in firebug? You should be able to just
> reference OpenLayers.js and LoadingPanel.js, add the stylesheet (with a
> valid path to the loading.gif), and add the control to your map. Did you
> download the loading.gif image and place it in your theme directory as your
> code shows? If not, you may be able to change the image path to *
> http://dev.openlayers.org/addins/loadingPanel/trunk/theme/default/img/loading.gif
> *.  Without a link to your map or a code snippet or firebug error, this is
> the best I can do to help you troubleshoot…
> Best of luck!
> BRYAN
> *Bryan R. McBride, GISP***
> GIS Programmer/Analyst
> *CHA* *~ Imagine What We Can Do For You!***
> 518.453.3975
> bmcbride at chacompanies.com
> www.chacompanies.com
> *From:* Kalyan Kamepalli [mailto:kalyan.kamepalli at gmail.com]
> *Sent:* Tuesday, August 24, 2010 7:36 PM
> *To:* McBride, Bryan
> *Subject:* Re: [OpenLayers-Users] Define several states of view
> (Zoom/Area)
> Hi Bryan,
> The document says ,
> *Use subversion to check out the **LoadingPanel*<http://svn.openlayers.org/addins/loadingPanel/trunk/>
> * addin. *
>            I downloaded LoadingPanel.js
> *Place the **LoadingPanel.js*<http://trac.openlayers.org/browser/addins/loadingPanel/trunk/lib/OpenLayers/Control/LoadingPanel.js>
> * file in your **Control*<http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Control>
> * directory (or alternatively, place it elsewhere and add a **<script>**tag to your page that points to it).
>           I placed it directly under openlayers folder but not under
> control directory. Added a script tag
>          <script src= "LoadingPanel.js"></script>
> *Use the **build tools* <http://trac.openlayers.org/wiki/Profiles>* to
> create a single file build (or link to your OpenLayers.js file to run in
> development mode).*
>         Is it  really needed to build a single file. I haven't done this
> part. What about linking to OpenLayers.js file ? How to
>         link LoadingPanel.js to OpenLayers.js ??
> *Add a stylesheet to your page to style the LoadingPanel (see examples). *
>           Added
>            .olControlLoadingPanel {
>             background-image:url(../theme/default/img/loading.gif);
>             position: relative;
>             width: 195px;
>             height: 11px;
>             background-position:center;
>             background-repeat:no-repeat;
>             display: none;
>         to my style.css
> *Construct a map and add a LoadingPanel to it*
> I added something like this to my HTML
> map
> .addControl( *new* OpenLayers.Control.LoadingPanel()) ;
> After all the above, I couldn't make my loading Panel working. Is there
> something that I am missing ??
> On Tue, Aug 24, 2010 at 11:10 PM, McBride, Bryan <
> Hi Kaylan,
> Everything you need for this should be available here:
> http://trac.openlayers.org/wiki/Addins/LoadingPanel
> BRYAN
> 518.453.3975
> *Sent:* Tuesday, August 24, 2010 7:41 AM
> (Zoom/Area)
> Hello Bryan,
> I would like to set up a status notifier/ progress bar something like the
> one you set up in geoexplorer. Is there any chance that you could that piece
> of code with me or could you give me any suggestion on setting one like that
> on my normal OpenLayers Map ??
> Cheers,
> Kalyan
> On Mon, Aug 16, 2010 at 11:08 PM, BMcBride <bmcbride at chacompanies.com>
> wrote:
> Hi Philippe,
> I have put together some
> http://www.bryanmcbride.com/blog/geoexplorer_hacks_2 documentation  for
> implementing similar "Quick Zooms" in GeoExplorer. GeoExplorer is a
> component of the  http://opengeo.org/community/suite/ OpenGeo Suite ,
> built
> on OpenLayers and GeoExt. You can see the "Quick Zooms" in action
> http://www.opengeohost.com/geoexplorer/ here . Hopefully this will get you
> going in the right direction!
> BRYAN
> http://www.bryanmcbride.com bryanmcbride.com
> http://geoserving.net/ geoserving.net
> http://osgeo-org.1803224.n2.nabble.com/Define-several-states-of-view-Zoom-Area-tp5427671p5427774.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100826/f6ac790a/attachment.html
