[OpenLayers-Users] OpenLayers.Control.SelectFeature with highlight, toggle
Christian Niemitz-Rossant cnr at m-click.de
Fri Aug 27 09:37:47 EDT 2010
Hi Eric,
after filing the ticket
http://trac.openlayers.org/ticket/2812
I got a message from Ilias, because he had to deal with the same
problem. His solution to add to the selectCtrl an onUnselect and in this
function to call
highlightCtrl.unhighlight(feature);
works fine for me. The two controls interfere and by calling a function
of one in the other solves the problem. Anyway I think that a solution
of only one control for highlight and select might be valuable, or?
Otherwise an example for this problem should be under examples and I
would be happy to provide it.
Kind regards,
Christian
Eric Lemoine wrote:
> On Thu, Aug 26, 2010 at 9:13 AM, Christian Niemitz-Rossant
> <cnr at m-click.de> wrote:
>> I have some troubles using feature selection with highlight and toggle:
>> In the OpenLayers example highlight-feature.html I replaced the line 55
>> which is
>> {clickout: true}
>> by
>> {toggle: true}
>> Then I applied these steps
>> 1. move cursor on the left triangle => triangle is highlighted
>> 2. click on the left triangle => triangle is selected
>> 3. move cursor out of the triangle => triangle is still selected
>> 4. move cursor on the left triangle => triangle is highlighted
>> 5. click on the triangle => triangle is normal
> I don't observe that. It gets selected in my case, which is expected I guess.
>> 6. move cursor out of the triangle => triangle is still normal
> It remains selected for me.
>> 7. move cursor on the triangle (no click!) => triangle is highlighted
>> 8. move cursor out of the triangle => triangle is shown as selected (without
>> click!?)
>> So somehow the select and the highlight get confused about the correct
>> style. The feature is not selected, but it is displayed as selected.
> Indeed. If I click the feature again to toggle it I also observe
> incorrect behavior when moving out and in.
>> It looks like a bug to me, but maybe there is another proposed way to use
>> highlight AND toggle at the same time (and hopefully including multiple).
> So yes there's a bug. Can you please create a ticket for it please?
> Thanks for reporting the problem.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100827/e6f78e28/attachment.html
