[OpenLayers-Users] WMS layers and Gmaps V3 with OL 2.9.1
christopher.schmidt at nokia.com
Mon Aug 30 00:31:36 EDT 2010
On Aug 29, 2010, at 11:51 AM, ext P Kishor wrote:
> On Sun, Aug 29, 2010 at 3:12 AM, Bart van den Eijnden <bartvde at osgis.nl> wrote:
>> There is not Google V3 support in 2.9.1.
>> Try 2.10 RC1.
> Sorry, no success. I replaced my OpenLayers to the hosted version of
> OpenLayers-2.10RC1, and used the code below. The Google layer shows,
> but my Counties layers does not.
> Suggestions?
Google Maps v3 support in OpenLayers requires that you use Spherical
Mercator as the projection. Review:
http://docs.openlayers.org/library/spherical_mercator.html
and try again.
-- Chris
>> Best regards,
>> Bart
>> Looking for flexible support on OpenLayers or GeoExt? Please check out http://www.osgis.nl/support.html
>> OSGIS
>> bartvde at osgis.nl
>> On Aug 29, 2010, at 6:38 AM, P Kishor wrote:
>>> I have the following, simplest possible code. Works without gmaps
>>> layer, but no WMS shows up when gmaps layer is included. What is it
>>> that I am doing wrong?
>>> <script type="text/javascript">
>>> function init(){
>>> var lon = -90.397;
>>> var lat = 45.93;
>>> var zoom = 5;
>>> var map = new OpenLayers.Map( 'map' );
>>> var layer = new OpenLayers.Layer.WMS(
>>> "OpenLayers WMS",
>>> "http://labs.metacarta.com/wms/vmap0",
>>> {layers: 'basic'}
>>> var counties = new OpenLayers.Layer.WMS(
>>> "Counties",
>>> "http://mapserv.ssec.wisc.edu/cgi-bin/mapserv?map=/opt/fgs/www/htdocs/research/Projects/LakesTSI/lakestsi2.map",
>>> layers: "Counties",
>>> map_imagetype: "agga",
>>> transparent: true,
>>> reproject: true,
>>> singleTile: true
>>> var gphy = new OpenLayers.Layer.Google(
>>> "Google Physical",
>>> {type: google.maps.MapTypeId.TERRAIN}
>>> // the following doesn't work
>>> map.addLayers([gphy, counties]);
>>> // the following works fine
>>> map.addLayers([layer, counties]);
>>> map.setCenter(new OpenLayers.LonLat(lon, lat).transform(
>>> new OpenLayers.Projection("EPSG:4326"),
>>> map.getProjectionObject()
>>> ), zoom);
>>> map.addControl( new OpenLayers.Control.LayerSwitcher() );
>>> </script>
>>> Puneet Kishor
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Puneet Kishor http://www.punkish.org
> Carbon Model http://carbonmodel.org
> Charter Member, Open Source Geospatial Foundation http://www.osgeo.org
> Science Commons Fellow, http://sciencecommons.org/about/whoweare/kishor
> Nelson Institute, UW-Madison http://www.nelson.wisc.edu
> Assertions are politics; backing up assertions with evidence is science
> Users mailing list
