[OpenLayers-Users] Changing a points location when drawing a polygon
Darren Karstens darrenkarstens at googlemail.com
Mon Feb 1 07:48:48 EST 2010
I need to change the location of a point on a polygon when it is created. I
tried adding a point callback:
	drawFeature.handler.callbacks.point = function(point) { return
pointCallback(point); }
then I tried changing the location of the point in the callback:
	function pointCallback(point)
 		point.x += 10;
		return point;
This didn't work. The point was created at the origional location and then
the cursor was moved to the new location (x+10). Does anyone know a way that
I can intercept the creation of this new node to change its location, or get
access to the new node after its created to change its position?
View this message in context: http://n2.nabble.com/Changing-a-points-location-when-drawing-a-polygon-tp4494150p4494150.html
