[OpenLayers-Users] right mouse drag?
Ivan Grcic igrcic at gmail.com
Wed Feb 3 10:08:05 EST 2010
...also DragPan doesnt have possibility to asign different keyMask to
handler. Maybe theres opened ticket for it somewhere, if not ill open
it.
cheers
On Wed, Feb 3, 2010 at 4:05 PM, Ivan Grcic <igrcic at gmail.com> wrote:
> Yes I managed to do it... I'll try to open a ticket for it...
> here's some tip... DragPan controls uses OpenLayers.Handler.Drag which
> has leftClick hardcoded in it:
> mousedown: function (evt) {
>        var propagate = true;
>        this.dragging = false;
>        if (this.checkModifiers(evt) && OpenLayers.Event.isMiddleClick(evt)) {
> We should make it optional so uses can make Drag handlers with left,
> right or middle click (ive also managed to do it)
> Again, ill try to open ticket this weekend..
> cheers
> On Tue, Feb 2, 2010 at 9:38 PM, Wendell Turner <wendell at enflight.com> wrote:
>> Is there an OpenLayers way to capture right mouse drag
>> events?
>> map.div.oncontextmenu works fine for right mouse clicks, and
>> OpenLayers.Handler.Drag seems to only work on the left mouse
>> button.  Is there some way to combine those?
>> Thanks,
>> Wendell
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Ivan Grcic
Ivan Grcic
