[OpenLayers-Users] WMS overlay not shown at zoom level 0 when singleTile: true
Tom B seileef at gmail.com
Wed Feb 3 13:41:51 EST 2010
Hi all,
In the attached code, the WMS overlay is shown fine at zoom level 1, but at
zoom level 0, it disappears.  If I either remove the "singleTile: true"
option, or use a MetaCarta base layer instead of the Google one, then the
overlay shows up fine at zoom level 0.
I took a look at the WMS request at map.layers[1].grid[0][0].url at zoom
level 0, and GeoServer renders that URL fine, so it looks like this issue is
related to OpenLayers.
Any ideas of what might be going wrong here?
Best,
Tom
<html xmlns="http://www.w3.org/1999/xhtml">
  <head>
	<script type="text/javascript"
src="http://maps.google.com/maps?file=api&amp;v=2&amp;sensor=false
&amp;key=ABQIAAAAmlH3GDvD6dTOdZjfrfvLFxTkTKGJ2QQt6wuPk9SnktO8U_sCzxTyz_WwKoSJx63MPLV9q8gn8KCNtg">
	</script>
    <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
    <script type="text/javascript">
        var lon = 5;
        var lat = 40;
        var zoom = 1;
        var map, layer;
        function init(){
        	var mapOptions = {
				controls: [],
				projection: new OpenLayers.Projection("EPSG:900913"),
				units: "m",
				maxResolution: 156543.0339,
				maxExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
20037508.34, 20037508.34),
				restrictedExtent: new OpenLayers.Bounds(-20037508.34, -20037508.34,
				minZoomLevel: 2
            map = new OpenLayers.Map('map', mapOptions);
			map.addControl(new OpenLayers.Control.PanZoomBar());
			if(true){
				var base_layer = new OpenLayers.Layer.Google(
					"Google Satellite",
						type: G_SATELLITE_MAP,
						sphericalMercator: true,
						isBaseLayer: true
			}else{
				var base_layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
					"http://labs.metacarta.com/wms/vmap0",
						layers: 'basic',
						isBaseLayer: true
			map.addLayer(base_layer);
			map.setBaseLayer(base_layer);
            map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
            map.addControl( new OpenLayers.Control.LayerSwitcher() );
			var new_layer = new OpenLayers.Layer.WMS('asdf',
"http://sds7.itc.virginia.edu:8080/thdl-geoserver/wms",
					layers: 'thl:roman_popular_poly',
					transparent: true,
					units: "m",
					CQL_FILTER: "fid=1"
					singleTile: true
			map.addLayer(new_layer);
    </script>
  </head>
  <body onload="init()">
    <div id="map" class="smallmap"></div>
  </body>
</html>
View this message in context: http://n2.nabble.com/WMS-overlay-not-shown-at-zoom-level-0-when-singleTile-true-tp4508945p4508945.html
