[OpenLayers-Users] Image layer maximum file size?
Lisa Gaudette lgaudette at ehealthinformation.ca
Fri Feb 5 10:40:37 EST 2010
I am trying to display pre-generated map images using an image layer;
these maps are to be used from the local machine.
The first set of images was created for a fairly small area at 5000 x
2500, with the images under 100kb each. I have had no problems
displaying these images. Then I had a set (representing a different,
much larger, area) that I made at 10000 x 12725 (~850kb). I could not
get it to display. I thought for a while that maybe it had something to
do with the height being greater than the width, but then I tried
creating that set at half the size 5000x6326 (~270kb), and things
worked. I then thought that perhaps a dimension over 10,000 was some
sort of maximum, so tried making them at 7800x9925 (~545kb). Didn't
work. There are no apparent errors, the image simply doesn't display.
When I right click in the map area and pick properties, it would seem
like the browser (IE - this must work with IE) thinks the image is there
and I get information about it (e.g. the correct address, size: 558646
bytes, Dimensions: 780x992 pixels).
For a simple code example, this is my modified version of the init()
function from the image-layer.html example:
        var map;
        function init(){
            map = new OpenLayers.Map('map');
            var options = {numZoomLevels: 6, maxResolution: 10};
            var imgWidth = 7800;
            var imgHeight = 9925;
            var graphic = new OpenLayers.Layer.Image(
                'Test',
                '/Maps/SK2/S/2/1588.png', // File size is 545kb
                new OpenLayers.Bounds(0, 0, imgWidth, imgHeight),
                new OpenLayers.Size(imgWidth, imgHeight),
                options
            map.addLayers([graphic]);
            map.zoomToMaxExtent();
Is this some maximum file size that it can load? Or perhaps some other
issue?
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100205/f4473b0c/attachment.html
