[OpenLayers-Users] Magnifier window
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Fri Feb 5 11:36:10 EST 2010
This code works if comment  " layers.length == 1"
var addLayersToMap = function()
var ov_overlays;
for( i in overlays )
{       map.addLayer( overlays[i] );
        ov_overlays = overlays[i].clone();
        ov_map.addLayer( ov_overlays );
        overlays[i].events.register('visibilitychanged', overlays[i],
function()
                        var layers = ov_map.getLayersByName(this.name); //
this is the layer
                        if(layers /*&& layers.length == 1*/)
 layers[0].setVisibility(this.getVisibility())
layers.length is always = 2
Why ov_map.getLayersByName(this.name) returns 2 layers?
Alexandre, i don't understand want you mean by
"and attach it to the original layer ( layer.clonedLayer = myCloneLayer )"
Do you think that could help with the length returned by
thanks
Steve
Alexandre Dube <adube at mapgears.com>@openlayers.org
Envoyé par : users-bounces at openlayers.org
05/02/2010 09:43 AM
A
cc
users at openlayers.org
Objet
Re: [OpenLayers-Users] Magnifier window
Steve,
  You could try (pseudo-code):
 For each layer
   Clone it, add it to ov-map and attach it to the original layer (
   Register a visibilitychange event to a onVisibilityChanged function
  onVisibilityChanged: function(event)
    this.clonedLayer.setVisibility(this.visibility())
Regards,
Alexandre
Alexandre Dube wrote:
> Steve,
>   Instead of relying on the layer's position in the layers array, try to
> use the following the getLayersByName method (see in my first reply).
> Tell me if that worked.
> Alexandre
> Steve.Toutant at inspq.qc.ca wrote:
>> Almost done....Amasing how things are easy to do with OL.
>> I have a wms layers array, "overlays[]"
>> I use this code to create the layers array of the overview map and to
>> define the visibilitychanged event.
>> for( i in overlays )//overlays contains my wms layers
>>         ov_overlays[i] = overlays[i].clone();
>>         ov_map.addLayer( ov_overlays[i] );
>>         //Ajoute un listener au niveau de la carte principal pour
>> gérer l'affichage sur la ov_map
>>         overlays[i].events.on(
>>                 'visibilitychanged': function(event)
>> ov_overlays[i].setVisibility(overlays[i].getVisibility());
>> in run time, only the visibility of the last layer of the array gets
>> updated in the other map.
>> I also tried with map.addLayers after adding the overlays[i]. events
>> on...with the same result
>> Do you see something wrong
>> thanks
>> Steve
>> *Alexandre Dube <adube at mapgears.com>*
>> 04/02/2010 03:36 PM
>> A
>> cc
>> Objet
>> Hi Steve,
>>  I think you could do something like that (pseudo-code) :
>>  Create your original map
>>  Create all your layers and add them to the map
>>  Create your ov-map
>>  Register a mapmove event to the map to make ov-map follow it
>>  For each layer
>>    Clone it and add it to ov-map
>>    var layers = ov-map.getLayersByName(this.name); // this is the layer
>> the visibility was changed
>>    if(layers && layers.length == 1)
>>      layers[0].setVisibility(this.visibility())
>> Do you get the idea ?
>> Best regards,
>> Alexandre
>>> Hi,
>>> I'm using openlayers with geoext.
>>> I would like to create a magnifier window. So it is like an overview
>>> map with a fix map center and a fix zoom level, but the main map and
>>> this overview map share the same geoext tree, so the layers are
>>> shown/hidden on both maps.
>>> I think I can do it if I start with the overview map example, here
>>> http://www.openlayers.org/dev/examples/example-list.html
>>> Does someone have a better idea or already tried this?
>>> thanks in advance
>>> Steve
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
>> Alexandre Dubé
>> Mapgears
>> www.mapgears.com
Alexandre Dubé
Mapgears
www.mapgears.com
Users mailing list
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100205/95524b1d/attachment.html
