[OpenLayers-Users] Modify object other then from muse click
Alexandre Dube adube at mapgears.com
Mon Feb 8 10:33:15 EST 2010
Poul,
you already keep track of your feature when selecting it with your
SelectFeature control :
selectedfeature = feature;
so you don't need to make any loop (you should also deactivate the
SelectFeature control too and do the opposite when your checkbox is
unchecked):
if (document.getElementById('checkbox_editable').checked==true)
				alert("Watch out!!!");
				drawControls["chooseobject"].unselect(selectedfeature);
				drawControls["chooseobject"].deactivate();
                                drawControls["modify_wfs_layer"].selectControl.select(selectedfeature);
				drawControls["modify_wfs_layer"].activate();
else {
    // do the opposite...
Regards,
Alexandre
paweluz wrote:
> Hi!
> Thanks for your help but unfortunately it does not work. Here is my code:
> My controlls
>             drawControls = {
>                 chooseobject: new OpenLayers.Control.SelectFeature(
> 					zielona_wfs,
> 						onSelect: onFeatureSelect
> 				modify_wfs_layer: new OpenLayers.Control.ModifyFeature(zielona_wfs)
> Getting the feature
>         function onFeatureSelect(feature) {
> Checkbox Onclick method
>                 function edit_object()
> 				for(var i=0; i<selectedfeature.length; i++)
> 					drawControls["chooseobject"].unselect(selectedfeature[i]);
> drawControls["modify_wfs_layer"].selectControl.select(selectedfeature[i]);
> The alert does not appear even once! I checked in firebug that
> selectedfeature is not empty. This is a screen from firebug
> http://i47.tinypic.com/2dwarzr.jpg
> I am not sure about the length property?? What do you thing. Maybe I made so
> mistake??
> Cheers,
> Poul
Alexandre Dubé
Mapgears
www.mapgears.com
