[OpenLayers-Users] Delete layer.vector on a map
Maxime Phaneuf maxime.phaneuf at usherbrooke.ca
Tue Feb 9 09:12:00 EST 2010
I think you have an error because you're removing layer[1], and right after
that, you're trying to destroy a layer that is already removed for the map's
list of layer.
I suppose you could just destroy the layer, or you could just remove it and
refresh the map object.
Maxime
View this message in context: http://n2.nabble.com/Delete-layer-vector-on-a-map-tp4540464p4541229.html
