[OpenLayers-Users] Appliaction loads the first google tile and then gives up
paweluz paweluz at o2.pl
Thu Feb 18 07:36:07 EST 2010
I have this same problem. Did anyone solve it?? Please write ....
agul wrote:
> Hi David I faced the sama problem but I couldnt solve if you find a way
> please write...
> David Potts wrote:
>> Hi
>> Am trying to load a google map via the gwt plug in and its not working.
>> As far as I can tell openlayers is correctly requesting the map tiles
>> from google maps(I have traced the net connection via firefox and you
>> can see all the tiles being downloaded)
>> When the program loads, a google map is shown in the left hand side of
>> the viewport, but its cliped to about a 3rd of the viewport.
>> If you scroll to the left or the right, the next tile is loaded, the
>> image now takes up two thirds of the viewport.
>> If you scroll to far to the right, the image drops back to left hand 1/3
>> of the viewport.
>> Dave.
View this message in context: http://n2.nabble.com/SelectFeature-control-and-click-event-on-marker-tp2186747p4591485.html
