[OpenLayers-Users] Beginner issue
ethio info info.ethio at gmail.com
Sun Feb 21 16:23:21 EST 2010
I understand what you are saying but my previous request was rejected
because it was over the size limit.
Here it is:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
    <meta http-equiv="Content-Type" content="text/html;charset=utf-8" />
    <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
    <!-- GLOBAL JAVASCRIPT -->
    <script src="http://www.latimes.com/includes/projects/js/menu.js"
type="text/javascript"></script>
    <script src='
http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ
'></script>
    <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
    <script type="text/javascript">
var index_map;
var wkt_f = new OpenLayers.Format.WKT();
function load_index_map() {
//    var max_extent = new
OpenLayers.Bounds(860986,-4383204,5870363,3600489);  //working but no
woreda's
OpenLayers.Bounds(660986,-4383204,4870363,3600489);//not working
    var options = {
        projection: new OpenLayers.Projection("EPSG:900913"),
        units: "m",
        maxResolution: 156543.0339,
        maxExtent: max_extent,
        minZoomLevel: 10,
        maxZoomLevel: 10,
        controls: []
    // Firing up the map object
    index_map = new OpenLayers.Map('index-map', options);
    // Google terrain map
    var gphy = new OpenLayers.Layer.Google("Google Terrain", {
        type: G_PHYSICAL_MAP,
        "sphericalMercator": true
    index_map.addLayer(gphy);
    index_map.addControl(new OpenLayers.Control.LayerSwitcher());
    index_map.addControl(new OpenLayers.Control.MousePosition());
    // Setting the feature style
    var template = {
        strokeColor : '#2262CC',
        strokeWidth: 2,
        strokeOpacity: 0.9,
        fillColor : '#2262CC',
        fillOpacity : 0.3,
        pointRadius : 3,
        strokeLinecap: "round"
    // Assigning the feature style
    var style = new OpenLayers.Style(template);
    var style_map = new OpenLayers.StyleMap({
        'default': style,
        'select': {
            fillColor: '#2262CC',
            fillOpacity: 0.75
    var hood_vector = new OpenLayers.Layer.Vector("Wereda");
    ar hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
8.8274792477, 39.3135039775    8.748488041, 39.3016324666    8.742095689,
39.3036871512    8.7357033371, 39.269899005    8.6920983646,
39.2315448931    8.6608214995, 39.2265223308    8.645982111,
39.2479823696    8.6108241751, 39.2249242428    8.589135838,
39.2221846634    8.5756662392, 39.2306316999    8.5656211146,
39.257114301    8.5601419558, 39.2502653525    8.5464440587,
39.2139659251    8.5220161421, 39.1744703218    8.4606039034,
39.0858905871    8.385037171, 39.0758454626    8.3950822956,
39.0381762455    8.399419963, 39.0363498593    8.5128842107,
39.0671701278    8.5432478827, 39.0655720398    8.5562608849,
39.0872603769    8.5968979797, 39.0874886751    8.6528310595, 39.10415445
8.6825098366, 39.0982186945    8.6939247509, 39.1075789242    8.7101339291,
39.1603158281    8.742095689, 39.1840588498    8.7877553461,
39.1767533046    8.8019098398, 39.2014095194    8.8146945437,
39.2057471869    8.8039645243, 39.2199016805    8.8012249449,
39.2461559833    8.8299905288, 39.2710404964    8.8224566854,
39.2968382026    8.8274792477 )))');
hood_polygon_371.data = {'slug':' 371', 'name': '371'};
var hood_polygon_260 = wkt_f.read('MULTIPOLYGON (((39.506872625
9.3384108099, 39.5290175587    9.3116999105, 39.510068801    9.2838475198,
39.522853505    9.2751721849, 39.4963709039    9.2509725667,
39.5105253976    9.2502876718, 39.5089273096    9.2354482833,
39.5290175587    9.2133033496, 39.5598378272    9.2203805965,
39.5456833335    9.1938979954, 39.5376928935    9.1470968469,
39.5771884968    9.0621698849, 39.5447701403    9.0523530586,
39.4872389725    9.0171951227, 39.461212968    9.0137706484,
39.4299361029    9.0452758117, 39.4004856241    9.0596586037,
39.3701219522    9.1025786813, 39.3758294093    9.126321703,
39.3498034048    9.1690134823, 39.2920439386    9.1770039223,
39.281085621    9.1865924503, 39.2514068439    9.2676383415,
39.2509502473    9.3203752454, 39.2584840907    9.3308769665,
39.266702829    9.3265392991, 39.3011758701    9.2909247666,
39.3253754883    9.3107867174, 39.3824500596    9.293664346, 39.434045472
9.3477710396, 39.4589299851    9.3511955139, 39.506872625    9.3384108099
hood_polygon_260.data = {'slug':' 260', 'name': '260'};
Wereda");
(hood_vector.addFeatures([hood_polygon_260,hood_polygon_371);
    var lon = 4387103;
    var lat = 1007363;
    var zoom = 0;
function show_hood(feature) {
        var selectedFeature = feature;
        var hood_name = selectedFeature.data.name;
        var hed = document.getElementById('hood-index-hed');
        hed.innerHTML = 'Click to visit ' + hood_name;
    function hide_hood() {
        hed.innerHTML = "Select one of L.A.&rsquo;s 114 neighborhoods";
    function click_hood(feature) {
        var url = '/mapping-la/neighborhoods/neighborhood/' +
selectedFeature.data.slug;
        index_map.destroy();
        window.location.href = url;
        return false;
    var hover_control = new OpenLayers.Control.SelectFeature(hood_vector, {
        hover: true,
        onSelect: show_hood,
        onUnselect: hide_hood,
        onHoverClick: click_hood
    index_map.addControl(hover_control);
    hover_control.activate();
    </script>
</head>
<body onload="load_index_map()" ><h2 style="font-size: 3em;
">Woreda's</h2>
    <div class="bottomborder pad5vert clear"
style="margin-right:20px;"></div>
    <!-- the dynamic hed -->
    <h1 class="pad10vert" id="hood-index-hed" >Select one of the 583
woreda's    </h1>
    <!-- The index map -->
<div id="index-map"  style="width: 1200px; height: 900px"></div>
</body>
</html>
On Sun, Feb 21, 2010 at 10:40 AM, Nicholas Efremov-Kendall <
n.e.kendall at gmail.com> wrote:
> you really need to post more code than that for someone to be able to help
> you. Are you using proj4.js to change your projection? OL only uses a few
> projections/coordinate systems natively.
> On Sun, Feb 21, 2010 at 2:39 AM, ethio info <info.ethio at gmail.com> wrote:
>> Hi, Please take a look at this site:
>> http://projects.latimes.com/mapping-la/neighborhoods/.
>> I have copied the source and cleaned it up of ads and so forth and have
>> put in my data and I just can not see the overlay on the Google map.
>> I will include the changes I made below.  The only thing I can think of
>> that is blocking my overlay is the bounds.  Basically, I want the country of
>> Ethiopia.
>> Just to complicate things further, my overlay was showing when I did not
>> use a spherical mercator projection but the overlay matched what is in
>> Google maps ONLY when I zoomed in.
>> so after reading some of the issues some people had, I figured I should
>> use what is in the Mapping LA w/minor changes.
>> Can someone suggest a solution?  BTW, the overlay switch works and gives
>> my overlay as a check box option to click on but it is not displayed on the
>> Google map
>> Here are my changes to the Mapping LA Neighborhood source:
>> var max_extent = new OpenLayers.Bounds(860986,-4383204,5870363,3600489);
>> var hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
>>     var lon = 4387103;
>>     var lat = 1007363;
>>     var zoom = 0;
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Fulbright Student 2009-2010, Ukraine
> nefremov at artsci.wustl.edu
> c/o Halyna Yerko
> Balzaka 92a, Kv 27
> 02232
> Kyiv, Ukraine
> (mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100221/911017a2/attachment.html
