[OpenLayers-Users] text marker question
Alexandre Dube adube at mapgears.com
Wed Feb 24 12:01:01 EST 2010
Karina,
  Sure.  Here's something to start from :
  yourVectorLayer.events.register("visibilitychanged", yourVectorLayer,
myOnChange);
  var myOnChange = function() {
    if(this.visibility === false) {
       //remove your popup
Alexandre
Karina Guardado wrote:
> thanks for your help and maybe you could provide me a code example
> about using this register event because I have never use this kind of
> object.
> thanks again,
> On Wed, Feb 24, 2010 at 9:52 AM, Alexandre Dube <adube at mapgears.com
> <mailto:adube at mapgears.com>> wrote:
>     Karina,
>      You could register a "visibilitychanged" event on your Layer.Text
>     object to close all popups on the map when the visibility is
>     changed to "false".
>     Alexandre
>         Hello,
>         When working with the text layer and click on one marker there
>         is not option to close it just to click on the icon again. Is
>         there any code to add a close button or something in this
>         window without having to click the icon again. The problem is
>         that users get confused when they open a window and then
>         disactive the text layer and the windows is still open but
>         there is not way to close it.
>         any suggestion , thanks,
>         karina
>         El salvador
>         _______________________________________________
>         Users mailing list
>         Users at openlayers.org <mailto:Users at openlayers.org>
>         http://openlayers.org/mailman/listinfo/users
>     Alexandre Dubé
>     Mapgears
>     www.mapgears.com <http://www.mapgears.com>
Alexandre Dubé
Mapgears
www.mapgears.com
