[OpenLayers-Users] NavToolbar BUG ?? ScrollWheel Zoom / MapClick ?
Bytechanger Bytechanger at gmx.de
Thu Feb 25 05:54:42 EST 2010
sorry, I wasn´t here last time...
I use the following Code to implement the Toolbar...
 map = new OpenLayers.Map('map',
                maxExtent:             new
OpenLayers.Bounds(maxExtend_minLON,     maxExtend_minLAT,
maxExtend_maxLON,    maxExtend_maxLAT),
                restrictedExtent:     new
OpenLayers.Bounds(Lon2Merc(minlon),Lat2Merc(minlat),
Lon2Merc(maxlon),Lat2Merc(maxlat)),
                numZoomLevels:         ZoomLevels, //17,
                eventListeners: {
                                    "zoomend": mapEvent
                maxResolution:         156543,
                units: 'm',
                projection:         new
OpenLayers.Projection("EPSG:900913"), // Kartenprojektion
                displayProjection:     new
OpenLayers.Projection("EPSG:4326"),
                controls: [
                            new OpenLayers.Control.MouseDefaults(),
                            new OpenLayers.Control.PanZoomBar(),
                            new OpenLayers.Control.ScaleLine(),
                             new OpenLayers.Control.NavToolbar()
map.events.register("mousedown", map, mapclick);    // THIS doesn´ t
work also when i use NavToolbar
Greetings
Byte
Am 19.02.2010 11:17, schrieb Marc Jansen:
> Hi Byte,
> which other controls are added to the map? Are you using controls: []
> within the config object to OpenLayers.Map?
> Regards,
> Marc
> Bytechanger wrote:
>> Hi,
>> when I add the NavToolbar to my map then :
>> - when I scroll with the mousewheel, the zoom-level steps not 10, 11, 12
>>    it steps 10,12,14, ...
>> - the mousclick event doesn´t work anymore !
>> when I remove the toolbar all this thinks works fine !
>> Greetings
>> Byte
View this message in context: http://n2.nabble.com/NavToolbar-BUG-ScrollWheel-Zoom-MapClick-tp4596496p4631766.html
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100225/36c9de41/attachment.html
