[OpenLayers-Users] Custom toolbars outside the map
Andreas Hocevar ahocevar at opengeo.org
Thu Feb 25 08:44:54 EST 2010
Frost89 wrote:
> Hi all
> I'm trying to add a custom toolbar to my map webapp. I was trying to use
> Control.Panel, but besides the standard controls in OpenLayers I also need
> to add some custom function such as print/user management and some others.
> So I was thinking if I would be able to make my own toolbar (I'm using a
> standard HTML <ul>) and then add a onClick handler, which could set the
> active tool to eg. being zoom in.
> Or are there any other alternatives?
There are many ways to do it for sure. But the OpenLayers way would be
to use Control.Panel, configure it with the div that you want it to be
rendered in (i.e. some container outside the map), and use
OpenLayers.Control.Button for your custom controls.
Look at the [1] example to see which css classes you need to give your
custom controls the icons you want, and [2] to see how to place it
outside the map.
Regards,
Andreas.
[1] http://openlayers.org/dev/examples/panel.html
[2] http://openlayers.org/dev/examples/editingtoolbar-outside.html
> / Kristian
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
