[OpenLayers-Users] Markers (circle, triangle, x, cross, etc) to be rendered in custom div?
Jonathan Sawyer jon at gina.alaska.edu
Thu Feb 25 19:48:22 EST 2010
Good afternoon OpenLayers community!
I have a question regarding the rendering of various build in graphic styles
(names). Can I render, say, a circle marker into a custom <div />?
For example:
Using these graphic names:
http://openlayers.org/dev/examples/graphic-name.html
I would like to be able to, as well as adding a feature to a layer using
that graphic name as its representation, store that exact graphic, as
rendered on the map, in a div element as a "key". I am building a user
interface that puts layers that have been added to the map into one portion
of the window. I want to identify the layer with its layer on the map via
the style its using.
I hope this makes sense. Thank you in advance!
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100225/3f19694b/attachment.html
