[OpenLayers-Users] Beginner issue
ethio info info.ethio at gmail.com
Thu Feb 25 21:12:11 EST 2010
Arnd, Thanks a lot, It works.   You helpled a lot and I appreciate it.
On Wed, Feb 24, 2010 at 1:21 PM, Arnd Wippermann <arnd.wippermann at web.de>wrote:
>  Hi,
>  1. you have to reproject your vector data (with EPSG:900913 and EPSG:4326
> it is possible without proj4js)
> 2. you have to add your vector layer to your map
> 3. you have to center the map
> //! set projections for transformation your vectors (before wkt_f.read)
>     wkt_f.internalProjection = new OpenLayers.Projection("EPSG:900913");
>     wkt_f.externalProjection = new OpenLayers.Projection("EPSG:4326");
> //! add vector layer
>     index_map.addLayer(hood_vector);
> //! set MouseDefaults for navigation
> index_map.addControl(new OpenLayers.Control.MouseDefaults());
> //! center map
>     index_map.setCenter(new OpenLayers.LonLat(lon, lat), zoom);
> that should show your map.
> Arnd
>  *Von:* users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
> *Im Auftrag von *ethio info
> *Gesendet:* Dienstag, 23. Februar 2010 21:51
> *An:* users at openlayers.org
> *Betreff:* Re: [OpenLayers-Users] Beginner issue
> Sorry to keep pestering you, but does anyone know what I am doing wrong?
> if anyone can make this work, and tell me how to fix it, I would be very
> grateful.
> thanks
> On Sun, Feb 21, 2010 at 3:23 PM, ethio info <info.ethio at gmail.com> wrote:
>> I understand what you are saying but my previous request was rejected
>> because it was over the size limit.
>> Here it is:
>> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "
>> http://www.w3.org/TR/html4/loose.dtd">
>> <html>
>> <head>
>>     <meta http-equiv="Content-Type" content="text/html;charset=utf-8" />
>>     <meta http-equiv="X-UA-Compatible" content="IE=EmulateIE7">
>>     <!-- GLOBAL JAVASCRIPT -->
>>     <script src="http://www.latimes.com/includes/projects/js/menu.js"
>> type="text/javascript"></script>
>>     <script src='
>> http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ<http://maps.google.com/maps?file=api&v=2&key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ>
>> '></script>
>>     <script src="http://www.openlayers.org/api/OpenLayers.js"></script>
>>     <script type="text/javascript">
>> var index_map;
>> var wkt_f = new OpenLayers.Format.WKT();
>> function load_index_map() {
>> //    var max_extent = new
>> OpenLayers.Bounds(860986,-4383204,5870363,3600489);  //working but no
>> woreda's
>> OpenLayers.Bounds(660986,-4383204,4870363,3600489);//not working
>>     var options = {
>>         projection: new OpenLayers.Projection("EPSG:900913"),
>>         units: "m",
>>         maxResolution: 156543.0339,
>>         maxExtent: max_extent,
>>         minZoomLevel: 10,
>>         maxZoomLevel: 10,
>>         controls: []
>>     // Firing up the map object
>>     index_map = new OpenLayers.Map('index-map', options);
>>     // Google terrain map
>>     var gphy = new OpenLayers.Layer.Google("Google Terrain", {
>>         type: G_PHYSICAL_MAP,
>>         "sphericalMercator": true
>>     index_map.addLayer(gphy);
>>     index_map.addControl(new OpenLayers.Control.LayerSwitcher());
>>     index_map.addControl(new OpenLayers.Control.MousePosition());
>>     // Setting the feature style
>>     var template = {
>>         strokeColor : '#2262CC',
>>         strokeWidth: 2,
>>         strokeOpacity: 0.9,
>>         fillColor : '#2262CC',
>>         fillOpacity : 0.3,
>>         pointRadius : 3,
>>         strokeLinecap: "round"
>>     // Assigning the feature style
>>     var style = new OpenLayers.Style(template);
>>     var style_map = new OpenLayers.StyleMap({
>>         'default': style,
>>         'select': {
>>             fillColor: '#2262CC',
>>             fillOpacity: 0.75
>>     var hood_vector = new OpenLayers.Layer.Vector("Wereda");
>>     ar hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
>> 8.8274792477, 39.3135039775    8.748488041, 39.3016324666    8.742095689,
>> 39.3036871512    8.7357033371, 39.269899005    8.6920983646,
>> 39.2315448931    8.6608214995, 39.2265223308    8.645982111,
>> 39.2479823696    8.6108241751, 39.2249242428    8.589135838,
>> 39.2221846634    8.5756662392, 39.2306316999    8.5656211146,
>> 39.257114301    8.5601419558, 39.2502653525    8.5464440587,
>> 39.2139659251    8.5220161421, 39.1744703218    8.4606039034,
>> 39.0858905871    8.385037171, 39.0758454626    8.3950822956,
>> 39.0381762455    8.399419963, 39.0363498593    8.5128842107,
>> 39.0671701278    8.5432478827, 39.0655720398    8.5562608849,
>> 39.0872603769    8.5968979797, 39.0874886751    8.6528310595, 39.10415445
>> 8.6825098366, 39.0982186945    8.6939247509, 39.1075789242    8.7101339291,
>> 39.1603158281    8.742095689, 39.1840588498    8.7877553461,
>> 39.1767533046    8.8019098398, 39.2014095194    8.8146945437,
>> 39.2057471869    8.8039645243, 39.2199016805    8.8012249449,
>> 39.2461559833    8.8299905288, 39.2710404964    8.8224566854,
>> 39.2968382026    8.8274792477 )))');
>> hood_polygon_371.data = {'slug':' 371', 'name': '371'};
>> var hood_polygon_260 = wkt_f.read('MULTIPOLYGON (((39.506872625
>> 9.3384108099, 39.5290175587    9.3116999105, 39.510068801    9.2838475198,
>> 39.522853505    9.2751721849, 39.4963709039    9.2509725667,
>> 39.5105253976    9.2502876718, 39.5089273096    9.2354482833,
>> 39.5290175587    9.2133033496, 39.5598378272    9.2203805965,
>> 39.5456833335    9.1938979954, 39.5376928935    9.1470968469,
>> 39.5771884968    9.0621698849, 39.5447701403    9.0523530586,
>> 39.4872389725    9.0171951227, 39.461212968    9.0137706484,
>> 39.4299361029    9.0452758117, 39.4004856241    9.0596586037,
>> 39.3701219522    9.1025786813, 39.3758294093    9.126321703,
>> 39.3498034048    9.1690134823, 39.2920439386    9.1770039223,
>> 39.281085621    9.1865924503, 39.2514068439    9.2676383415,
>> 39.2509502473    9.3203752454, 39.2584840907    9.3308769665,
>> 39.266702829    9.3265392991, 39.3011758701    9.2909247666,
>> 39.3253754883    9.3107867174, 39.3824500596    9.293664346, 39.434045472
>> 9.3477710396, 39.4589299851    9.3511955139, 39.506872625    9.3384108099
>> hood_polygon_260.data = {'slug':' 260', 'name': '260'};
>> Wereda");
>> (hood_vector.addFeatures([hood_polygon_260,hood_polygon_371);
>>     var lon = 4387103;
>>     var lat = 1007363;
>>     var zoom = 0;
>>  function show_hood(feature) {
>>         var selectedFeature = feature;
>>         var hood_name = selectedFeature.data.name;
>>         var hed = document.getElementById('hood-index-hed');
>>         hed.innerHTML = 'Click to visit ' + hood_name;
>>     function hide_hood() {
>>         hed.innerHTML = "Select one of L.A.&rsquo;s 114 neighborhoods";
>>     function click_hood(feature) {
>>         var url = '/mapping-la/neighborhoods/neighborhood/' +
>> selectedFeature.data.slug;
>>         index_map.destroy();
>>         window.location.href = url;
>>         return false;
>>     var hover_control = new OpenLayers.Control.SelectFeature(hood_vector,
>>         hover: true,
>>         onSelect: show_hood,
>>         onUnselect: hide_hood,
>>         onHoverClick: click_hood
>>     index_map.addControl(hover_control);
>>     hover_control.activate();
>>     </script>
>> </head>
>> <body onload="load_index_map()" ><h2 style="font-size: 3em;
>> ">Woreda's</h2>
>>     <div class="bottomborder pad5vert clear"
>> style="margin-right:20px;"></div>
>>     <!-- the dynamic hed -->
>>     <h1 class="pad10vert" id="hood-index-hed" >Select one of the 583
>> woreda's    </h1>
>>     <!-- The index map -->
>> <div id="index-map"  style="width: 1200px; height: 900px"></div>
>> </body>
>> </html>
>>   On Sun, Feb 21, 2010 at 10:40 AM, Nicholas Efremov-Kendall <
>> n.e.kendall at gmail.com> wrote:
>>> you really need to post more code than that for someone to be able to
>>> help you. Are you using proj4.js to change your projection? OL only uses a
>>> few projections/coordinate systems natively.
>>>  On Sun, Feb 21, 2010 at 2:39 AM, ethio info <info.ethio at gmail.com>wrote:
>>>>  Hi, Please take a look at this site:
>>>> http://projects.latimes.com/mapping-la/neighborhoods/.
>>>> I have copied the source and cleaned it up of ads and so forth and have
>>>> put in my data and I just can not see the overlay on the Google map.
>>>> I will include the changes I made below.  The only thing I can think of
>>>> that is blocking my overlay is the bounds.  Basically, I want the country of
>>>> Ethiopia.
>>>> Just to complicate things further, my overlay was showing when I did not
>>>> use a spherical mercator projection but the overlay matched what is in
>>>> Google maps ONLY when I zoomed in.
>>>> so after reading some of the issues some people had, I figured I should
>>>> use what is in the Mapping LA w/minor changes.
>>>> Can someone suggest a solution?  BTW, the overlay switch works and gives
>>>> my overlay as a check box option to click on but it is not displayed on the
>>>> Google map
>>>> Here are my changes to the Mapping LA Neighborhood source:
>>>> var max_extent = new OpenLayers.Bounds(860986,-4383204,5870363,3600489);
>>>> var hood_polygon_371 = wkt_f.read('MULTIPOLYGON (((39.2968382026
>>>>     var lon = 4387103;
>>>>     var lat = 1007363;
>>>>     var zoom = 0;
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
>>> Fulbright Student 2009-2010, Ukraine
>>> nefremov at artsci.wustl.edu
>>> c/o Halyna Yerko
>>> Balzaka 92a, Kv 27
>>> 02232
>>> Kyiv, Ukraine
>>> (mob) +380963576524
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100225/a70ecd78/attachment.html
