[OpenLayers-Users] get feature info
Herman Badenhorst hbadenhorst at hotmail.com
Mon Jan 4 01:44:26 EST 2010
Hi all.
I've got a layer called "vw_map_rsa_2009" with the following attributes:
fid
gid
mapunit
country_code
map_name
map_id
mapping_unit_id
lus
degradation_code
degradation_area
degradation_degree
conservation_code
conservation_area
conservation_effectiveness
I have an input form where the "mapping_unit_id" is a field that the user
can type OR select from a map.
When the user clicks on the map, the "mapping_unit_id" must be populated in
the input form.
How do i get the "mapping_unit_id" from the layer?
Regards,
Herman
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100104/9ef6efd5/attachment.html
