[OpenLayers-Users] get feature info
Bart van den Eijnden bartvde at osgis.nl
Mon Jan 4 05:04:08 EST 2010
Hi Herman,
use OpenLayers.Control.WMSGetFeatureInfo and listen to the getfeatureinfo event, you'll get an array of features, then check feature.attributes for its values.
See:
http://dev.openlayers.org/releases/OpenLayers-2.8/examples/getfeatureinfo-control.html
Best regards,
Bart
On Jan 4, 2010, at 10:31 AM, Herman Badenhorst wrote:
> Hi all.
> I've got a layer called "vw_map_rsa_2009" with the following attributes:
> fid
> gid
> mapunit
> country_code
> map_name
> map_id
> mapping_unit_id
> lus
> degradation_code
> degradation_area
> degradation_degree
> conservation_code
> conservation_area
> conservation_effectiveness
> I have an input form where the "mapping_unit_id" is a field that the user can type OR select from a map.
> When the user clicks on the map, the "mapping_unit_id" must be populated in the input form.
> How do i get the "mapping_unit_id" from the layer?
> Regards,
> Herman
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20100104/c95033a1/attachment.html
